Hi All!
I modified UIPEthernet library for ENC28j60 ethernet chip.
This library have compatible API with WizNet W5100 Ethernet library.
Original UIPEthernet writed by Norbert Truchsess.
Modifications:
- Replaced import to include, because gcc say 'import is deprecated'.
- Added support for STM32F, and ESP8266 MCU-s.
- Merged martinayotte's modification (Correct s_dhcp 40K more memory usage with STM32F MCU-s.)
- Moved htons,ntohs,htonl,ntohl definitions to uip.h.
- Corrected infinite loops.
- Set the version to 1.2.0
- Corrected ESP8266 exception(28).
- Added watchdog reset calls in functions for stable running on ESP8266.
- Added geterevid function to get ENC28j60 chip erevid (revision information).
- Changed linkStatus to static for outside call.
- Added functions bypass, if can't communicate with ethernet device.
- Added SPI bus instabil communication detection.
- Changed debuging/logging. Remove individual debuging. Add global and scalable debuging feature.
You can setup debuging/logging level in utility/logging.h
You can use this header file in Your scetch too.
Add "LogObject" define for serial logging/debuging with board specific default setting.
- Added support to MBED/SMeshStudio IDE. (Compiled to STM32F103RB (Nucleo).)
Can You use more MCU-s (Atmel AVR-s,Arduino Due,STM32F series(Maple Mini),ESP8266).
Can You use Arduino IDE, and MBED/SMeshStudio.
You find more wirings in hardware directory.
You can download from: https://github.com/UIPEthernet/UIPEthernet
Hi All!
Modifications:
