Hi All!
I modified UIPEthernet for MBED/SMeshStudio.
Original UIPEthernet writed by Norbert Truchsess.
UIPEthernet have compatible API with Wiznet W5100 Ethernet library.
I modified:
- Replaced import to include, because gcc say 'import is deprecated'.
- I merged martinayotte's modification (Correct s_dhcp 40K more memory usage with STM32F MCU-s.)
- Add support for STM32F, and ESP8266 MCU-s.
- Moved htons,ntohs,htonl,ntohl definitions to uip.h.
- Correct infinite loops.
- Set the version to 1.2.0
(This version tested on ESP8266 too. Working properly. Without watchdog resets.)
- Correct ESP8266 exception(28).
- Add watchdog reset calls in functions for stable running on ESP8266.
- Add geterevid function to get ENC28j60 chip erevid (revision information).
- Change linkStatus to static for outside call.
- Add functions bypass, if can't communicate with ethernet device.
- Add SPI bus instabil communication detection.
- Change debuging/logging. Remove individual debuging. Add global and scalable debuging feature.
You can setup debuging/logging level in utility/logging.h
You can use this header file in Your scetch too.
Add "LogObject" define for serial logging/debuging with board specific default setting.
- Add support for MBED/SMeshStudio IDE.
I only compiled with SMeshStudio (STM32F103RB). Not uploaded and tested with device.
I compiled with Arduino IDE and uploaded to maple mini a tested. Working properly.
You can download from:https://github.com/UIPEthernet/UIPEthernet
Best regards
Hi All!
I modified:
Best regards
