I'm very very new to mbed and so I have a fairly newbie question. Also, I asked a question earlier, but don't know what the difference is between a question and a discussion.
So /media/uploads/mentality2/main.cpp is my code. It's modified from the original template as I couldn't get that working.
My LED is blinking as it should be when the pin is low (using USB) and it's measured to be around 0V. I use a resistor and connect it to the VIN pin and it's reading 4.9V, but it's still blinking. So either something's wrong with my code, or I'm doing something wrong?
Is there a specific circuit or resistor I'm supposed to use? Is the voltage not high enough? Is there not enough current? Or am I totally off track?
My "push user button and make LED blink" program works fine.
Thank you
Thank you
