Hello folks,
New to this world, I am trying to write an assembler only application with the mbed compiler.
To do this i create a Main.s source file containing the program below (which do nothing! but serve just to see if it is working)
This code is very similar to the ARM documentation
AREA main, CODE ; Name of code main
MOVS r0, #10 ; Set up parameters
MOVS r1, #3
ADD r0, r0, r1 ; r0 = r0 + r1
END
I get a compiler error 241
What i have done so far is introducing some modification in the code ( like changing MOVS by MOV) to prove that the assembler is doing the job by issuing error and this the case. I guess that the assembly job is done and that the problem may come at the linkedit level (but not sure).
My questions:
Is there some documentation about the error codes?
Can someone give me the explanation of error 241.
Many thanks in advance
Gérard
Hello folks, New to this world, I am trying to write an assembler only application with the mbed compiler. To do this i create a Main.s source file containing the program below (which do nothing! but serve just to see if it is working) This code is very similar to the ARM documentation
--------------AREA main, CODE ; Name of code main
MOVS r1, #3
END
-------------I get a compiler error 241
My questions: Is there some documentation about the error codes?
Gérard
