EDIT
My getValue syntax for the ConfigFile library was wrong
Original Code(NOT WORKING):
if (_cfg.getValue(sbNameKey, &sbNameValue[0], sizeof(sbNameValue[0]))) {}
Working Code:
if (_cfg.getValue(sbNameKey, &sbNameValue[0], sizeof(sbNameValue))) {}
My code works along side of ConfigFile to grab keys and values from the SETTINGS.CFG file that is located on my mbed. Please view http://mbed.org/users/d0773d/code/ for the complete code example. There will be a code list for Sensors, and my two libraries: cfExtensions and msExtensions
I am not sure why sbNameValue value is blank. I declared the sbNameValue in the cfExtensions.h file.
This works as a test:
//As a test, outputs FirstStart which is the correct value.
_msAccess->sendSomething(sbFirstStartKey)
What am I not doing correctly to get the value from: char sbFirstStartValue[BUFSIZ]?
Here are sections of code from the original files:
//File: cfExtensions.h
class cfExtensions
public:
char sbFirstStartValue[BUFSIZ];
void msSendSomething();
void getFirstStartValue();
//File: cfExtensions.cpp:
void cfExtensions::msSendSomething() {
_msAccess->sendSomething(sbNameValue);
// Load Config File
void cfExtensions::loadConfigFile() {
* Read a configuration file from a mbed.
if (!_cfg.read("/local/settings.cfg")) {
printf("Failure to read a configuration file.");
} // End of loadConfigFile
// Get ConfigFile Values
void cfExtensions::getFirstStartValue() {
if (_cfg.getValue(sbFirstStartKey, &sbFirstStartValue[0], sizeof(sbFirstStartValue[0]))) {}
// Check if MBED First Start
void cfExtensions::checkConfigForFirstStart() {
* Get a configuration value.
//This works : _msAcess->sendSomething(sbFirstStartKey);
printf("{\"sb\": \"%s\"}\r\n", sbFirstStartValue);
_msAccess->sendSomething(sbFirstStartValue);
if (strcmp(&sbFirstStartValue[0], "TRUE") == 0) {
_msAccess->sendSomething("checkConfigForFirstStart() EXECUTED!");
_msAccess->sendSomething(cfExtensions::sbNameValue);
pingTick.attach(this, &cfExtensions::msSendSomething, 10);
while(!_pc->readable()) {
if (cfExtensions::pingTicked) {
cfExtensions::pingTicked = false;
if(_pc->readable()) {
pingTick.detach();
_cfg.setValue("FirstStart", "FALSE");
_cfg.write("/local/settings.cfg");
} // End of checkConfigForFirstStart
<<code>>
<<code>>
//File: msExtensions.h
class msExtensions
public:
// Function Prototypes
msExtensions(); // Default Constructor
msExtensions(MODSERIAL *pc); // Constructor, Initialization tasks
void pcRecvInterrupt(MODSERIAL_IRQ_INFO *q);
void pingBaseStation();
int msBaud();
void sendSomething(char* txt);
<</code>>
<<code>>
//File msExtensions:
void msExtensions::sendSomething(char* txt) {
printf("{\"sbPing\": \"%s\"}\r\n", txt);
} // End of pingBaseStation function
EDIT
Working Code:
What am I not doing correctly to get the value from: char sbFirstStartValue[BUFSIZ]? Here are sections of code from the original files:
