CNC polishing machines, like most polishing machines, consist of basic components such as a base, a polishing turret, a polishing roller, a polishing head, a polishing cover and a cover. The polishing head is fixed on the base, and the taper sleeve for fixing the polishing disc is connected to the motor shaft through a screw. The polishing fabric is fastened to the polishing disk by a ferrule. After the motor is turned on by the switch on the base, the sample can be manually pressed to polish the rotating polishing disk.
The polishing liquid added during the polishing process can flow into the square plate placed beside the polishing machine through a drain pipe in a plastic tray fixed to the base.
The polishing cover and cover prevent the dirt and other debris from falling on the polished workpiece such as the stainless steel head or the can body when the machine is not in use, which affects the use effect.
The key to the operation of CNC polishing machine equipment is to try to obtain a large polishing rate in order to remove the damage layer generated during polishing as quickly as possible. At the same time, the polishing damage layer will not affect the observed tissue, that is, it will not cause false tissue. The former requires the use of coarser abrasives to ensure a higher polishing rate to remove the polished damage layer, but the polishing damage layer is also deeper; the latter requires the use of the finest material to make the polishing damage layer shallower, but polished The rate is low.
http://www.cnpolishing.com
