using the wifly and the mbed i encounter yet another odd problem. The problem is that the 2nd time function "Mod" was call , the scanf was unable to accept any input value ... the code is as follow
Serial wifi(p28, p27);
int //the list is a bit long but all varaible are declared as integer
void Mod()
int Confirm; //use to confirm if it is the desired input
Confirm=0;
do
fflush(stdin);
FHz = 0;
wifi.printf("\r\nFertilizing frequency in hrs?\r\n");
while(FHz == 0)
fflush(stdin);
wifi.scanf("%d", &FHz);
wifi.getc();
if(FHz == 0)
{ wifi.printf("\r\nPlease enter the frequency again\r\n");
wifi.printf("\r\nThe fertilizer frequency is %d hrs? If not enter 1, if yes enter 0\r\n", FHz);
wifi.scanf("%d", &Confirm);
wifi.getc();
Min1=FHz*60;
}while(Confirm==1);
Confirm=0;
// the exact same thing is repeated for 3 otherr variable and ended with the following code
wifi.printf("\r\nTo make any changes to the value input the word mod into tera term\r\n");
mod2=0;
void Menu()//below is a portion of the menu function that deal with mod function
char Text[100];
wifi.scanf("%s", &Text);
wifi.getc();
char Mod[4] ="Mod";
if (strcasecmp(Mod,Text) == 0)
if(Process==0)
mod2=1;
else
wifi.printf("System is in operation, change of variable is locked . Please try again later.\r\n");
//following is the main prorgam
// Main program
//Intialization State
PHY_PowerDown();//Ethernet powerdown
result = semihost_powerdown();//USB power down (Note need new firmware)
set_time(NULL);
Close.fall(&ULS);
//insert code for drawing of data
char start[100];
char Boot[5] = "Boot";
while(1)
{ fflush(stdin);
void flush();
wifi.scanf("%s", &start);
wifi.getc();
if (strcasecmp(Boot,start) == 0)
wifi.printf("\r\nBooting System, please standby\r\n");
// wait(3);
wifi.printf("All system green\r\n");
wifi.printf("Please input the following variables\r\n");
Mod();
Ready=2;
while(Ready==2)
if (Prevent==0)
FT.attach(Fert,180);
MT.attach(Moist,1200);
wifi.attach(&Menu);
Prevent=1;
if(mod2==1)
fflush(stdin);
Mod();
Sleep();
the error is that when I type in mod after the first call of mod , it is able to bring up the function . however any input I type will either yield A)no respond or B)
print "Please enter the frequency again"
i trying to fflush(stdin) to see if it will resolve it but it dint seem to work ~ could anyone advice me on what is wrong ?
P.S : if it lacking detail do let me know thanks again for your help
#include "mbed.h" Serial wifi(p28, p27); int //the list is a bit long but all varaible are declared as integer void Mod() { int Confirm; //use to confirm if it is the desired input Confirm=0; do { fflush(stdin); FHz = 0; wifi.printf("\r\nFertilizing frequency in hrs?\r\n"); while(FHz == 0) { fflush(stdin); wifi.scanf("%d", &FHz); wifi.getc(); if(FHz == 0) { wifi.printf("\r\nPlease enter the frequency again\r\n"); } } wifi.printf("\r\nThe fertilizer frequency is %d hrs? If not enter 1, if yes enter 0\r\n", FHz); wifi.scanf("%d", &Confirm); wifi.getc(); Min1=FHz*60; }while(Confirm==1); Confirm=0; // the exact same thing is repeated for 3 otherr variable and ended with the following code ... wifi.printf("\r\nTo make any changes to the value input the word mod into tera term\r\n"); mod2=0; void Menu()//below is a portion of the menu function that deal with mod function { char Text[100]; wifi.scanf("%s", &Text); wifi.getc(); char Mod[4] ="Mod"; if (strcasecmp(Mod,Text) == 0) { if(Process==0) { mod2=1; } else { wifi.printf("System is in operation, change of variable is locked . Please try again later.\r\n"); } } //following is the main prorgam int main() { // Main program //Intialization State PHY_PowerDown();//Ethernet powerdown result = semihost_powerdown();//USB power down (Note need new firmware) set_time(NULL); Close.fall(&ULS); //insert code for drawing of data char start[100]; char Boot[5] = "Boot"; while(1) { fflush(stdin); void flush(); wifi.scanf("%s", &start); wifi.getc(); if (strcasecmp(Boot,start) == 0) { wifi.printf("\r\nBooting System, please standby\r\n"); // wait(3); wifi.printf("All system green\r\n"); wifi.printf("Please input the following variables\r\n"); Mod(); Ready=2; } while(Ready==2) { if (Prevent==0) { FT.attach(Fert,180); MT.attach(Moist,1200); wifi.attach(&Menu); Prevent=1; } if(mod2==1) { fflush(stdin); Mod(); } Sleep(); } } }the error is that when I type in mod after the first call of mod , it is able to bring up the function . however any input I type will either yield A)no respond or B) print "Please enter the frequency again"
