Hi!
I just installed the qp framework to my embed using the dining philosophers example http://mbed.org/users/QL/programs/qp_dpp/ly37cg
Previously I installed the TextLCD library http://mbed.org/users/simon/libraries/TextLCD/livod0 and modified it slightly to allow for 16x4 displays.
I got the TextLCD library to work previously and to show text on my LCD display, but after installing the qp framework I cannot figure out how to make it work. If I put any of the lcd (LCD defined to this name) commands, e.g. lcd.cls(), the QP software just stop running just after start. I call the lcd from a function in the bsp.cpp, which in turn is called from the philo.cpp initial state. The calling from the initial state to the bsp.cpp works if I do not use lcd functions in the bsp.cpp code.
I tried to find any examples on how to use a LCD through a library such as the TextLCD, but did not find any.
Any ideas on how to call the lcd functions when using the qp framework?
Thanks in advance!
- Axel
Hi!
Thanks in advance!
- Axel
