Good analysis of the logic specs, appreciate the help. If you don't mind, I would like to state my opinion that a user shouldn't have to look in the forums to get this information. Whether a user is interfacing with linear ICs such as comparators or using discrete devices or diode logic, or simply wants to see what his noise margins are with traditional logic, these specifications are important and should be easy to find. It certainly should not require looking at the schematic and going to the LPC1768 specifications as we had to do. Just guessing, I would say the reason these specs don't appear on the pinout page is that the original engineer probably didn't know, but now we do! Every logic IC in the world has this information (really), so I suggest the good people at MBED add at least the basic I/O specs shown below to the pinout page.
By the way, the 40 mA spec is not exactly correct either. Please see the following new topic.
http://mbed.org/forum/bugs-suggestions/topic/3364/
MBED rocks, and I hope this helps.
Recommended wording of logic levels:
Digital IO:
Input low state requires <= 0.8 V
Input high state requires >= 2.0 V
Input will tolerate up to 5 V high state
Output high state is >= 2.9 V with 4 mA current out of pin
Output low state is <= 0.4 V with 4 mA current into pin
Output short circuit limited to 40 mA (maximum 400 mA total)
Are the logic inputs TTL or CMOS? Could not find on this page:
http://mbed.org/handbook/mbed-NXP-LPC1768
It is confusing because the following page describes both cases but does not say which the MBED actually is.
http://mbed.org/users/4180_1/notebook/pushbuttons/
I need complete specs including low state threshold voltage. Thanks.
