String to Integer - atoi does not work ?
19 Jan 2012
    if (cfg.getValue(key5, &value[0], sizeof(value))) {usbUART.printf("'%s'='%s'\n\r", key5, value);} //lcl_port
    lcl_port = atoi(key5); //Update udp port
    usbUART.printf("lcl_port = %d\n\r", lcl_port);
The first printf works, i get "44444"
The result of second = 0
What am i doing wrong?
Theo (nl)
19 Jan 2012
do you mean atoi of the key ? or did you mean to atoi the value ?
Not knowing what your key was.. would it atoi anyway ?
19 Jan 2012
Hi David,
Thanks for the hint. it indeed should have read:
lcl_port = atoi(value); //Update udp port
Theo (nl)
