What can I do ?? Pleease Help
I cannot see my compilers that i have written
Fatal Application Error: Resource object failed to load.
?request=/eNqLT423LSlKTQUADYMDEQ==&tree_id=nav_tree&tree_node_id=%2F&tree_node_path=1
<br />
<b>Fatal error</b>: Uncaught exception 'MBED_EXCEPTION' with message 'The program doesn't exist: Yueksel_2' in /var/lib/mbed/compiler/releases/current/mbed/include/core.obj.php:733
Stack trace:
- 0 /var/lib/mbed/compiler/releases/current/mbed/include/program.obj.php(82): MBED_CORE->exception('The program doe...')
- 1 /var/lib/mbed/compiler/releases/current/mbed/include/program.obj.php(1615): MBED_PROGRAM->check_exists()
- 2 /var/lib/mbed/compiler/releases/current/mbed/include/tree.php(43): MBED_PROGRAM->check_system_folders(0)
- 3 /var/lib/mbed/compiler/releases/current/mbed/functionality/tree.inc.php(61): tree_scan_projects(Object(TheITF_Control_Tree))
- 4 /var/lib/mbed/compiler/releases/current/theitf/system/modules/functions.inc.php(60): require('/var/lib/mbed/c...')
- 5 /var/lib/mbed/compiler/releases/current/index.php(326): execute('tree')
- 6 {main}
thrown in <b>/var/lib/mbed/compiler/releases/current/mbed/include/core.obj.php</b> on line <b>733</b><br />
Please contact support and describe how you get this message
What can I do ?? Pleease Help I cannot see my compilers that i have written
<br /> <b>Fatal error</b>: Uncaught exception 'MBED_EXCEPTION' with message 'The program doesn't exist: Yueksel_2' in /var/lib/mbed/compiler/releases/current/mbed/include/core.obj.php:733 Stack trace:
