Syntax-Query get one of the bits after PortIn or BusIn
06 Dec 2011
Hi all, After reading the port, I need to use "pins"as a 4 bit binary number,
PortIn p(Port0, 0x00000C30);
pins=p.read();
I'm using C to compile.
1. Define Binary : Which type should I define the "pins" as? Is that int?
2. Fetch 1 bit from (int?): And after that how can I fetch each bit from the 4 bits. Should I write like pins[0],pins[1],etc
10 Dec 2011
something like this?
int pins = p.read();
int result = 0, s=3;
for( int mask=0x00000C30; mask; mask>>=1, pins>>=1)
  if( mask&1)
    result |= (pins&1) << s;
    --s;
Or just use BusIn, it returns the bits in the order you've chosen the pins.
