Hello guys, I was doing an project using 2 xbee to communicate with each other and once they are able to communicate, they would play a wav file. However I encountered a problem which is that the xbee is able to communicate with each other, but the wave file are not be able to play. Hope you guys can help me!
//Programming for XBEE//
#include "SDFileSystem.h"
#include "wave_player.h"
Serial xbee1(p9, p10); //Creates a variable for serial comunication through pin 9 and 10
DigitalOut rst1(p11); //Digital reset for the XBee, 200ns for reset
DigitalOut myled(LED1); //Create variable for Led 1 on the mbed
DigitalOut myled1(LED2);//Create variable for Led 2 on the mbed
SDFileSystem sd(p5, p6, p7, p8, "sd");
AnalogOut DACout(p18);
wave_player waver(&DACout);
int req ;
mkdir("/sd/wf/", 0777); // make the directory to the SD card
// 0777 is the default mode so to have the widest access
FILE *fp0 = fopen("/sd/wf/1.wav", "r");
FILE *fp1 = fopen("/sd/wf/2.wav", "r");
FILE *fp2 = fopen("/sd/wf/3.wav", "r");
FILE *fp3 = fopen("/sd/wf/4.wav", "r");
FILE *fp4 = fopen("/sd/wf/5.wav", "r");
FILE *fp5 = fopen("/sd/wf/6.wav", "r");
FILE *fp6 = fopen("/sd/wf/7.wav", "r");
FILE *fp7 = fopen("/sd/wf/8.wav", "r");
FILE *fp8 = fopen("/sd/wf/9.wav", "r");
FILE *fp9 = fopen("/sd/wf/10.wav", "r");
FILE *fp10 = fopen("/sd/wf/11.wav", "r");
FILE *fp11 = fopen("/sd/wf/12.wav", "r");
FILE *fp12 = fopen("/sd/wf/13.wav", "r");
FILE *fp13 = fopen("/sd/wf/14.wav", "r");
FILE *fp14 = fopen("/sd/wf/15.wav", "r");
FILE *fp15 = fopen("/sd/wf/16.wav", "r");
FILE *fp16 = fopen("/sd/wf/17.wav", "r");
FILE *fp17 = fopen("/sd/wf/18.wav", "r");
FILE *fp18 = fopen("/sd/wf/19.wav", "r");
FILE *fp19 = fopen("/sd/wf/20.wav", "r");
FILE *fp20 = fopen("/sd/wf/30.wav", "r");
FILE *fp21 = fopen("/sd/wf/40.wav", "r");
FILE *fp22 = fopen("/sd/wf/50.wav", "r");
FILE *fp23 = fopen("/sd/wf/60.wav", "r");
FILE *fp24 = fopen("/sd/wf/70.wav", "r");
FILE *fp25 = fopen("/sd/wf/80.wav", "r");
FILE *fp26 = fopen("/sd/wf/90.wav", "r");
FILE *fp27 = fopen("/sd/wf/Bus.wav", "r");
FILE *fp28 = fopen("/sd/wf/is approaching.wav", "r");
rst1 = 0; //Set reset pin to 0
myled = 0;//Set LED1 to 0
myled1 = 0;//Set LED2 to 0
wait_ms(1);//Wait at least one millisecond
rst1 = 1;//Set reset pin to 1
wait_ms(1);//Wait another millisecond
if(fp1 == NULL){
printf("File couldn't open\n");
while (1)
if (xbee1.readable())
req = xbee1.getc();
printf("%c\n", req);
if (req == 'r')
xbee1.printf("100\n");
waver.play(fp27);
waver.play(fp9);
waver.play(fp28);
fseek(fp27, 0, SEEK_SET); // set file poiter to beginning
fseek(fp9, 0, SEEK_SET);
fseek(fp28, 0, SEEK_SET);
wait(1);
Here is my programming:
//Programming for XBEE// #include "mbed.h" #include "SDFileSystem.h" #include "wave_player.h" Serial xbee1(p9, p10); //Creates a variable for serial comunication through pin 9 and 10 DigitalOut rst1(p11); //Digital reset for the XBee, 200ns for reset DigitalOut myled(LED1); //Create variable for Led 1 on the mbed DigitalOut myled1(LED2);//Create variable for Led 2 on the mbed SDFileSystem sd(p5, p6, p7, p8, "sd"); AnalogOut DACout(p18); wave_player waver(&DACout); int main() { int req ; mkdir("/sd/wf/", 0777); // make the directory to the SD card // 0777 is the default mode so to have the widest access FILE *fp0 = fopen("/sd/wf/1.wav", "r"); FILE *fp1 = fopen("/sd/wf/2.wav", "r"); FILE *fp2 = fopen("/sd/wf/3.wav", "r"); FILE *fp3 = fopen("/sd/wf/4.wav", "r"); FILE *fp4 = fopen("/sd/wf/5.wav", "r"); FILE *fp5 = fopen("/sd/wf/6.wav", "r"); FILE *fp6 = fopen("/sd/wf/7.wav", "r"); FILE *fp7 = fopen("/sd/wf/8.wav", "r"); FILE *fp8 = fopen("/sd/wf/9.wav", "r"); FILE *fp9 = fopen("/sd/wf/10.wav", "r"); FILE *fp10 = fopen("/sd/wf/11.wav", "r"); FILE *fp11 = fopen("/sd/wf/12.wav", "r"); FILE *fp12 = fopen("/sd/wf/13.wav", "r"); FILE *fp13 = fopen("/sd/wf/14.wav", "r"); FILE *fp14 = fopen("/sd/wf/15.wav", "r"); FILE *fp15 = fopen("/sd/wf/16.wav", "r"); FILE *fp16 = fopen("/sd/wf/17.wav", "r"); FILE *fp17 = fopen("/sd/wf/18.wav", "r"); FILE *fp18 = fopen("/sd/wf/19.wav", "r"); FILE *fp19 = fopen("/sd/wf/20.wav", "r"); FILE *fp20 = fopen("/sd/wf/30.wav", "r"); FILE *fp21 = fopen("/sd/wf/40.wav", "r"); FILE *fp22 = fopen("/sd/wf/50.wav", "r"); FILE *fp23 = fopen("/sd/wf/60.wav", "r"); FILE *fp24 = fopen("/sd/wf/70.wav", "r"); FILE *fp25 = fopen("/sd/wf/80.wav", "r"); FILE *fp26 = fopen("/sd/wf/90.wav", "r"); FILE *fp27 = fopen("/sd/wf/Bus.wav", "r"); FILE *fp28 = fopen("/sd/wf/is approaching.wav", "r"); rst1 = 0; //Set reset pin to 0 myled = 0;//Set LED1 to 0 myled1 = 0;//Set LED2 to 0 wait_ms(1);//Wait at least one millisecond rst1 = 1;//Set reset pin to 1 wait_ms(1);//Wait another millisecond if(fp1 == NULL){ printf("File couldn't open\n"); } while (1) { if (xbee1.readable()) { req = xbee1.getc(); printf("%c\n", req); if (req == 'r') xbee1.printf("100\n"); waver.play(fp27); waver.play(fp9); waver.play(fp28); fseek(fp27, 0, SEEK_SET); // set file poiter to beginning fseek(fp9, 0, SEEK_SET); fseek(fp28, 0, SEEK_SET); wait(1); } } }
