MyClass.cpp
#include "MyClass.h"
MyClass::MyClass(PinName tx, PinName rx) : _MySerial(tx, rx, 512) {
_MySerial.baud(230400);
_MySerial.attach(callback(this, &MyClass::_RxCallback), Serial::RxIrq);
Compiler's errors
Building project stm32l476_mbed (NUCLEO_L476RG, GCC_ARM)
Scan: .
Scan: mbed
Scan: env
Scan: FEATURE_COMMON_PAL
Compile [ 73.9%]: stm32l4xx_hal_msp_template.c
Compile [ 74.2%]: stm32l4xx_hal_iwdg.c
Compile [ 74.5%]: stm32l4xx_hal_i2c_ex.c
Compile [ 74.8%]: stm32l4xx_hal_lcd.c
Compile [ 75.1%]: stm32l4xx_hal_lptim.c
Compile [ 75.4%]: stm32l4xx_hal_nand.c
Compile [ 75.7%]: stm32l4xx_hal_opamp.c
Compile [ 75.9%]: stm32l4xx_hal_opamp_ex.c
Compile [ 76.2%]: stm32l4xx_hal_irda.c
Compile [ 76.5%]: stm32l4xx_hal_nor.c
Compile [ 76.8%]: stm32l4xx_hal_pcd_ex.c
Compile [ 77.1%]: stm32l4xx_hal_pwr.c
Compile [ 77.4%]: stm32l4xx_hal_pcd.c
[Warning] stm32l4xx_hal_pcd.c@1418,11: comparison between signed and unsigned integer expressions [-Wsign-compare]
[Warning] stm32l4xx_hal_pcd.c@1433,13: comparison between signed and unsigned integer expressions [-Wsign-compare]
Compile [ 77.7%]: stm32l4xx_hal_pwr_ex.c
Compile [ 78.0%]: stm32l4xx_hal_rng.c
Compile [ 78.3%]: stm32l4xx_hal_rcc.c
Compile [ 78.6%]: main.cpp
[Warning] http_request.h@143,28: comparison between signed and unsigned integer expressions [-Wsign-compare]
[Warning] http_request.h@162,28: comparison between signed and unsigned integer expressions [-Wsign-compare]
[Error] NonCopyable.h@157,5: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::SerialBase]' is private
[Error] SerialBase.h@42,7: within this context
[Error] NonCopyable.h@157,5: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::RawSerial]' is private
[Error] RawSerial.h@53,7: within this context
[ERROR] In file included from ./main.h:13:0,
from ./main.cpp:1:
./mbed-http/source/http_request.h: In member function 'HttpResponse* HttpRequest::send(const void*, nsapi_size_t)':
./mbed-http/source/http_request.h:143:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (send_result != request_size) {
./mbed-http/source/http_request.h:162:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (nparsed != recv_ret) {
In file included from ./mbed-os/rtos/Thread.h:32:0,
from ./mbed-os/rtos/rtos.h:31,
from ./mbed-os/mbed.h:38,
from ./main.h:4,
from ./main.cpp:1:
./mbed-os/platform/NonCopyable.h: In copy constructor 'mbed::SerialBase::SerialBase(const mbed::SerialBase&)':
./mbed-os/platform/NonCopyable.h:157:5: error: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::SerialBase]' is private
NonCopyable(const NonCopyable&);
In file included from ./mbed-os/drivers/Serial.h:24:0,
from ./mbed-os/mbed.h:81,
from ./main.h:4,
from ./main.cpp:1:
./mbed-os/drivers/SerialBase.h:42:7: error: within this context
class SerialBase : private NonCopyable<SerialBase> {
In file included from ./mbed-os/mbed.h:88:0,
from ./main.h:4,
from ./main.cpp:1:
./mbed-os/drivers/RawSerial.h: In copy constructor 'mbed::RawSerial::RawSerial(const mbed::RawSerial&)':
./mbed-os/drivers/RawSerial.h:53:7: note: synthesized method 'mbed::SerialBase::SerialBase(const mbed::SerialBase&)' first required here
class RawSerial: public SerialBase, private NonCopyable<RawSerial> {
from ./main.h:4,
from ./main.cpp:1:
./mbed-os/platform/NonCopyable.h:157:5: error: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::RawSerial]' is private
from ./main.h:4,
from ./main.cpp:1:
./mbed-os/drivers/RawSerial.h:53:7: error: within this context
In file included from ./MyClass.h:5:0,
from ./main.h:9,
from ./main.cpp:1:
./easy-connect/esp8266-driver/ESP8266/ATParser/BufferedSerial/BufferedSerial.h: In copy constructor 'BufferedSerial::BufferedSerial(const BufferedSerial&)':
./easy-connect/esp8266-driver/ESP8266/ATParser/BufferedSerial/BufferedSerial.h:71:7: note: synthesized method 'mbed::RawSerial::RawSerial(const mbed::RawSerial&)' first required here
class BufferedSerial : public RawSerial
In file included from ./main.h:9:0,
from ./main.cpp:1:
./MyClass.h: In copy constructor 'MyClass::MyClass(const MyClass&)':
./MyClass.h:27:7: note: synthesized method 'BufferedSerial::BufferedSerial(const BufferedSerial&)' first required here
class MyClass {
./main.cpp: At global scope:
./main.cpp:7:87: note: synthesized method 'MyClass::MyClass(const MyClass&)' first required here
MyClass cam = MyClass(MBED_CONF_APP_CAM_TX, MBED_CONF_APP_CAM_RX, MBED_CONF_APP_CAM_RESET);
[mbed] ERROR: "/usr/bin/python" returned error code 1.
I am trying to move some pieces of my code to a class named MyClass where I have a private member BufferedSerial _mySerial. Unfortunately, I got a lot of compiler's errors that I don't know how to resolve. I will appreciate any help that anyone can provide.
MyClass.h
#include "mbed.h" #include "BufferedSerial.h" class MyClass { public: // define which pins are used MyClass(PinName tx, PinName rx); private: BufferedSerial _MySerial; void _RxCallback(); };MyClass.cpp
#include "MyClass.h" MyClass::MyClass(PinName tx, PinName rx) : _MySerial(tx, rx, 512) { _MySerial.baud(230400); _MySerial.attach(callback(this, &MyClass::_RxCallback), Serial::RxIrq); }Compiler's errors
Building project stm32l476_mbed (NUCLEO_L476RG, GCC_ARM) Scan: . Scan: mbed Scan: env Scan: FEATURE_COMMON_PAL Compile [ 73.9%]: stm32l4xx_hal_msp_template.c Compile [ 74.2%]: stm32l4xx_hal_iwdg.c Compile [ 74.5%]: stm32l4xx_hal_i2c_ex.c Compile [ 74.8%]: stm32l4xx_hal_lcd.c Compile [ 75.1%]: stm32l4xx_hal_lptim.c Compile [ 75.4%]: stm32l4xx_hal_nand.c Compile [ 75.7%]: stm32l4xx_hal_opamp.c Compile [ 75.9%]: stm32l4xx_hal_opamp_ex.c Compile [ 76.2%]: stm32l4xx_hal_irda.c Compile [ 76.5%]: stm32l4xx_hal_nor.c Compile [ 76.8%]: stm32l4xx_hal_pcd_ex.c Compile [ 77.1%]: stm32l4xx_hal_pwr.c Compile [ 77.4%]: stm32l4xx_hal_pcd.c [Warning] stm32l4xx_hal_pcd.c@1418,11: comparison between signed and unsigned integer expressions [-Wsign-compare] [Warning] stm32l4xx_hal_pcd.c@1433,13: comparison between signed and unsigned integer expressions [-Wsign-compare] Compile [ 77.7%]: stm32l4xx_hal_pwr_ex.c Compile [ 78.0%]: stm32l4xx_hal_rng.c Compile [ 78.3%]: stm32l4xx_hal_rcc.c Compile [ 78.6%]: main.cpp [Warning] http_request.h@143,28: comparison between signed and unsigned integer expressions [-Wsign-compare] [Warning] http_request.h@162,28: comparison between signed and unsigned integer expressions [-Wsign-compare] [Error] NonCopyable.h@157,5: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::SerialBase]' is private [Error] SerialBase.h@42,7: within this context [Error] NonCopyable.h@157,5: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::RawSerial]' is private [Error] RawSerial.h@53,7: within this context [ERROR] In file included from ./main.h:13:0, from ./main.cpp:1: ./mbed-http/source/http_request.h: In member function 'HttpResponse* HttpRequest::send(const void*, nsapi_size_t)': ./mbed-http/source/http_request.h:143:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (send_result != request_size) { ^ ./mbed-http/source/http_request.h:162:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (nparsed != recv_ret) { ^ In file included from ./mbed-os/rtos/Thread.h:32:0, from ./mbed-os/rtos/rtos.h:31, from ./mbed-os/mbed.h:38, from ./main.h:4, from ./main.cpp:1: ./mbed-os/platform/NonCopyable.h: In copy constructor 'mbed::SerialBase::SerialBase(const mbed::SerialBase&)': ./mbed-os/platform/NonCopyable.h:157:5: error: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::SerialBase]' is private NonCopyable(const NonCopyable&); ^ In file included from ./mbed-os/drivers/Serial.h:24:0, from ./mbed-os/mbed.h:81, from ./main.h:4, from ./main.cpp:1: ./mbed-os/drivers/SerialBase.h:42:7: error: within this context class SerialBase : private NonCopyable<SerialBase> { ^ In file included from ./mbed-os/mbed.h:88:0, from ./main.h:4, from ./main.cpp:1: ./mbed-os/drivers/RawSerial.h: In copy constructor 'mbed::RawSerial::RawSerial(const mbed::RawSerial&)': ./mbed-os/drivers/RawSerial.h:53:7: note: synthesized method 'mbed::SerialBase::SerialBase(const mbed::SerialBase&)' first required here class RawSerial: public SerialBase, private NonCopyable<RawSerial> { ^ In file included from ./mbed-os/rtos/Thread.h:32:0, from ./mbed-os/rtos/rtos.h:31, from ./mbed-os/mbed.h:38, from ./main.h:4, from ./main.cpp:1: ./mbed-os/platform/NonCopyable.h:157:5: error: 'mbed::NonCopyable<T>::NonCopyable(const mbed::NonCopyable<T>&) [with T = mbed::RawSerial]' is private NonCopyable(const NonCopyable&); ^ In file included from ./mbed-os/mbed.h:88:0, from ./main.h:4, from ./main.cpp:1: ./mbed-os/drivers/RawSerial.h:53:7: error: within this context class RawSerial: public SerialBase, private NonCopyable<RawSerial> { ^ In file included from ./MyClass.h:5:0, from ./main.h:9, from ./main.cpp:1: ./easy-connect/esp8266-driver/ESP8266/ATParser/BufferedSerial/BufferedSerial.h: In copy constructor 'BufferedSerial::BufferedSerial(const BufferedSerial&)': ./easy-connect/esp8266-driver/ESP8266/ATParser/BufferedSerial/BufferedSerial.h:71:7: note: synthesized method 'mbed::RawSerial::RawSerial(const mbed::RawSerial&)' first required here class BufferedSerial : public RawSerial ^ In file included from ./main.h:9:0, from ./main.cpp:1: ./MyClass.h: In copy constructor 'MyClass::MyClass(const MyClass&)': ./MyClass.h:27:7: note: synthesized method 'BufferedSerial::BufferedSerial(const BufferedSerial&)' first required here class MyClass { ^ ./main.cpp: At global scope: ./main.cpp:7:87: note: synthesized method 'MyClass::MyClass(const MyClass&)' first required here MyClass cam = MyClass(MBED_CONF_APP_CAM_TX, MBED_CONF_APP_CAM_RX, MBED_CONF_APP_CAM_RESET); ^ [mbed] ERROR: "/usr/bin/python" returned error code 1.
