I am trying to turn off the physical ethernet interface on the LPC1768 board. As well as the official mbed SDK, I have imported Michael Wei's Power Control library (containing the files EthernetPowerControl.cpp, EthernetPowerControl.h and PowerControl.h)
The top of my main.cpp file shows the following:
#include "PowerControl/EthernetPowerControl.h"
The main function starts:
PHY_PowerDown(); //does this line turn off the ethernet physical interface?
//other code
When I try to compile this, I get an error message:
Quote:
Error: Cannot open source input file "TARGET_LPC1768/LPC17xx.h": No such file or directory in "PowerControl/PowerControl.h", Line: 9, Col: 37
Please can someone suggest a solution? If I have to find the file LPC17xx.h, where should I import it from?
int main() { PHY_PowerDown(); //does this line turn off the ethernet physical interface? //other code }When I try to compile this, I get an error message:
