Hello all,
iam trying to build a USBHid Device with the provided examples, that can be found here: https://developer.mbed.org/handbook/USBHID.
In general the example is working, but there arrives no data at the controller.
The statement if(hid.read(&recv_report)) in line 33 evaluates to true, when i send messages with the python code attached below, but the report always has a length of 0 and it contains no data.
The problem is the same with mbed 2 and mbed 5.
Does anybody got an idea of what might be wrong with my code?
slightly modified version of example
#include "USBHID.h"
//We declare a USBHID device. Input out output reports have a length of 8 bytes
USBHID hid(8, 8);
//This report will contain data to be sent
HID_REPORT send_report;
HID_REPORT recv_report;
Serial pc(USBTX, USBRX);
Timer debugTimer;
int main(void) {
debugTimer.start();
send_report.length = 8;
while (1)
//Fill the report
for (int i = 0; i < send_report.length; i++)
send_report.data[i] = rand() & 0xff;
//Send the report
hid.send(&send_report);
//try to read a msg
pc.printf("received at %d, length of report %d: ", debugTimer.read_us(), recv_report.length);
for(int i = 0; i < 8; i++)
pc.printf("%d ", recv_report.data[i]);
pc.printf("\r\n");
wait(0.2);
python side with pywinusb
import pywinusb.hid as hid
from time import sleep
import random
# handler called when a report is received
def rx_handler(data):
print 'recv: ', data
def findHIDDevice(mbed_usage, mbed_vendor_id):
# Find all devices connected
all_devices = hid.HidDeviceFilter(vendor_id = mbed_vendor_id).get_devices()
if not all_devices:
print "No device connected"
else:
# search for the Mbed
for HIDdevice in all_devices:
try:
HIDdevice.open()
# browse output reports
for report in HIDdevice.find_output_reports():
if mbed_usage in report:
#MBED found
print 'Mbed detected'
print report
#Attach a custom handler when a data is received
HIDdevice.set_raw_data_handler(rx_handler)
#send a report each 0.2 second. The report is a random array of 8 bytes
while True:
for i in range(8):
report[mbed_usage][i] = random.randint(0, 255)
report.send()
sleep(0.2)
except:
print 'close'
print traceback.format_exc()
HIDdevice.close()
if __name__ == '__main__':
# The vendor ID used in the Mbed program
mbed_vendor_id = 0x1234
# Vendor page and usage_id = 2
mbed_usage = hid.get_full_usage_id(0xffab, 0x02)
# Search the Mbed, attach rx handler and send data
Hello all,
#include "mbed.h" #include "USBHID.h" //We declare a USBHID device. Input out output reports have a length of 8 bytes USBHID hid(8, 8); //This report will contain data to be sent HID_REPORT send_report; HID_REPORT recv_report; Serial pc(USBTX, USBRX); Timer debugTimer; int main(void) { debugTimer.start(); send_report.length = 8; while (1) { //Fill the report for (int i = 0; i < send_report.length; i++) { send_report.data[i] = rand() & 0xff; } //Send the report hid.send(&send_report); //try to read a msg if(hid.read(&recv_report)) { pc.printf("received at %d, length of report %d: ", debugTimer.read_us(), recv_report.length); for(int i = 0; i < 8; i++) { pc.printf("%d ", recv_report.data[i]); } pc.printf("\r\n"); } wait(0.2); } }python side with pywinusb
import pywinusb.hid as hid from time import sleep import random # handler called when a report is received def rx_handler(data): print 'recv: ', data def findHIDDevice(mbed_usage, mbed_vendor_id): # Find all devices connected all_devices = hid.HidDeviceFilter(vendor_id = mbed_vendor_id).get_devices() if not all_devices: print "No device connected" else: # search for the Mbed for HIDdevice in all_devices: try: HIDdevice.open() # browse output reports for report in HIDdevice.find_output_reports(): if mbed_usage in report: #MBED found print 'Mbed detected' print report #Attach a custom handler when a data is received HIDdevice.set_raw_data_handler(rx_handler) #send a report each 0.2 second. The report is a random array of 8 bytes while True: for i in range(8): report[mbed_usage][i] = random.randint(0, 255) report.send() sleep(0.2) except: print 'close' print traceback.format_exc() HIDdevice.close() if __name__ == '__main__': # The vendor ID used in the Mbed program mbed_vendor_id = 0x1234 # Vendor page and usage_id = 2 mbed_usage = hid.get_full_usage_id(0xffab, 0x02) # Search the Mbed, attach rx handler and send data findHIDDevice(mbed_usage, mbed_vendor_id)
