Some C++ help: Character arrays, pointers, and strings, oh my.
25 Sep 2011
Ok, including my sample code below.
What I'm ultimately working on: I need to pass a string to a function, and be able to find the size of the string, and add the characters to a character array. I'm working on an I2C OLED driver... so trying to read in a string from one source, and pass it out to the display driver.
Where I'm stumbling... If I have a char * mystring then sizeof(mystring) should equal sizeof(pointer). However, shouldn't sizeof(&mystring) return the size of the contents of the string?
The code below also has a little snippet to make the led's on the header act as a binary out. ;)
Where I'm doing my testing is commented, for your pleasure.
DigitalOut myled1(LED1);DigitalOut myled2(LED2);DigitalOut myled3(LED3);DigitalOut myled4(LED4);
void report (int number);
int test_1(char * mypointer);
int test_2(char mystring[]);
int test_3(char mystring);
    char * characterstringpointer = "abcdefghij";
    char characterstring[] = "abcdefghij";
    while (1) {
        // A pointer, I expect 4 (pointer = int = 4 bytes)
        report(sizeof(characterstringpointer));
        // I get 4.
        // Data at pointer, I expect 11 (10 + \0)
        report(sizeof(&characterstringpointer));
        // I get 4?!
        // Returns sizeof data at pointer, I expect 11 (10 + \0)
        report(test_1(characterstringpointer));
        // I get 4?!
        // Returns sizeof raw character array, I expect 11 (10 + \0)
        report(sizeof(characterstring));
        // I get 11
        // Tries to pass the array as an array then get sizeof, I expect 11 (10 + \0)
        report(test_2(characterstring));
        // I get 4?! -- This one is 'bad' but testing for completeness
        // Tries to pass as a 'char', which should act as a string, then get sizeof, I expect 11 (10 + \0)
        // I get 4?!
        wait(5);
int test_1(char * mypointer) {
    return(sizeof(&mypointer));
int test_2(char mystring[]) {
    return(sizeof(mystring));
int test_3(char mystring) {
void report (int number) {
    switch (number) {
    case 0:  myled1 = 0;myled2 = 0;myled3 = 0;myled4 = 0; break;
    case 1:  myled1 = 0;myled2 = 0;myled3 = 0;myled4 = 1; break;
    case 2:  myled1 = 0;myled2 = 0;myled3 = 1;myled4 = 0; break;
    case 3:  myled1 = 0;myled2 = 0;myled3 = 1;myled4 = 1; break;
    case 4:  myled1 = 0;myled2 = 1;myled3 = 0;myled4 = 0; break;
    case 5:  myled1 = 0;myled2 = 1;myled3 = 0;myled4 = 1; break;
    case 6:  myled1 = 0;myled2 = 1;myled3 = 1;myled4 = 0; break;
    case 7:  myled1 = 0;myled2 = 1;myled3 = 1;myled4 = 1; break;
    case 8:  myled1 = 1;myled2 = 0;myled3 = 0;myled4 = 0; break;
    case 9:  myled1 = 1;myled2 = 0;myled3 = 0;myled4 = 1; break;
    case 10: myled1 = 1;myled2 = 0;myled3 = 1;myled4 = 0; break;
    case 11: myled1 = 1;myled2 = 0;myled3 = 1;myled4 = 1; break;
    case 12: myled1 = 1;myled2 = 1;myled3 = 0;myled4 = 0; break;
    case 13: myled1 = 1;myled2 = 1;myled3 = 0;myled4 = 1; break;
    case 14: myled1 = 1;myled2 = 1;myled3 = 1;myled4 = 0; break;
    case 15: myled1 = 1;myled2 = 1;myled3 = 1;myled4 = 1; break;
    default: myled1 = 1;myled2 = 1;myled3 = 1;myled4 = 1; break;
    wait(2.0);myled1 = 0;myled2 = 0;myled3 = 0;myled4 = 0;
    wait(0.1);myled1 = 1;myled2 = 1;myled3 = 1;myled4 = 1;
    wait(0.1);myled1 = 0;myled2 = 0;myled3 = 0;myled4 = 0;
    wait(0.2);
