Transistors
30 Aug 2011
Hello, I need a transistor in a circuit, but I don't know how to code for it.
How do I code for a transistor?
30 Aug 2011
What are you doing with the transistor ?
Are you just driving a light bulb, or relay, Or is it patron of a SMPSU ? Is it Lo-side, or Hi-side ? A single transistor, or darlington ? Linear, or analogue O/P
Tell us more, so we can help !
Ceri.
30 Aug 2011
Yeah a bit more info would be useful. Generally you connect a digital output to the base of a transistor (through a resistor - good practice) and drive a load connected to the collector or emitter of the transistor (depending on if it's a NPN or PNP transistor).
With some more info we would be able to help you out more.
30 Aug 2011
Actually, I'm an idiot, it's not a transistor - it's a capacitor.
30 Aug 2011
We still need more info to help !
Ceri.
30 Aug 2011
Well, I figure I need a capacitor to get higher output...
30 Aug 2011
30 Aug 2011
I want to go higher than 5v
30 Aug 2011
Do you want to switch a higher voltage ?
Perhaps 12 - 24 Volts ?
Then a transistor is what you need. But once again, give some info so someone could Give you a solution.
Ceri.
30 Aug 2011
I shall need to get a transistor first... hurrm hurrm
