Read data from sd card
20 Jul 2011
Is it possible to read the stored data from the SDcard.If it is possible please give me an example. Thanking you
20 Jul 2011
Have a look in the cookbook ;-) There are some examples ....
Regards kokisan
20 Jul 2011
21 Jul 2011
for reading just replace the "w" in the fopen command with "r" and use fgetc or fgets to read a single byte or a string from the file:
      // example of reading a file one byte at a time
      // and display it in hex format on the terminal
      unsigned char c;                          // a single byte buffer
      FILE *fp = fopen("/sd/myfile.txt", "r");  // open the file in 'read' mode
      while (!feof(fp)){                        // while not end of file
           c=fgetc(fp);                         // get a character/byte from the file
           printf("Read from file %02x\n\r",c); // and show it in hex format
      fclose(fp);                               // close the file
If you want to read more data at once use fgets instead.
24 Oct 2016
how can I save and read integer values from sdcard. Do I have to write fgetd?
