Operating system
Development tools
Security and connectivity
Important update: Arm Announces End of Life Timeline for Mbed. This site will be archived in July 2026. Read the full announcement.
Fred Scipione.
2
replies
This looks like it should work. The relays should toggle on and off every second for four cycles. What are you seeing as the actual behavior?
Other Comments:
1. For clarity, you might make the following changes to the bits of the program that write to the SPI port:
// Initialization
device.format(16,0); // 16 bits, clock idles low, data capture on rising edge
pulse = 0; // Initialize the latch signal
device.write(0x0000); // Write 16 bits of data to the SPI to clear the relay port
pulse = 1; // Latch the preceding data
wait_us(1); // Enforce a minimum inter-transfer interval
// Subsequent writes are as follows
pulse = 0; // De-assert the latch signal
device.write(0xnnnn); // Write 16 bits of data to the SPI
In the example above, the "pulse" signal is wrapped tightly around the actual SPI transfer. This is important if you are sharing the SPI channel with another device, because any data written to the SPI controller will be received by the simple parallel port circuit and the latch pulse will blindly capture the last data transfer. So you want to latch the desired data right after it is written, and not allow for the chance that a transfer to another device might squeeze in between the writing of the desired data and the assertion of the latch pulse.
The behavior just described will not cause a problem for you in your simple test program, but it could crop up as your hardware expands. Hence the suggested changes.
2. Have you checked the relay wiring to make sure it behaves as expected? For example, if you remove the wire that runs from pin 15 of U1 to pin 1 of U3, then connect pin 1 of U3 to +3.3V, relay 0 should activate.
David,
If Hexley's code has not done the trick for you, I suggest that the next step is to use a test program for a 'divide-and-conquer' approach. The circuit in your schematic does not seem to have any timing constraints, so you should be able to check-out just the hardware side if you could 'wiggle' the three interface lines 'by-hand'. Once you are sure the hardware is working, you are free to concentrate on getting the software to match the hand-generated pattern(s) that worked.
The test program should operate as follows:
With the test program running, you can use a terminal program to set or clear each of the 3 signals (from the keyboard) and check the results with a voltmeter.
Next you can type (or cut-and-paste) strings of characters that should control the outputs of U1. Get just the Q1 output under control ("0HL+-+" vs "1HL+-+"), then all 8/9 (checking with a voltmeter). Then see if the U1 outputs are passing through U3. Type more (longer) patterns to check all 16 bits on all the IC's.
Finally, dump a large pattern from a text file to run a long sequence of bit patterns and waits. At 9600 Baud, the text file should be able to simulate a 240 Hz clock rate. At this point you should be confident that the hardware is all working. Try some higher baud rates if you wish (keep the test program and terminal settings matched :-)). Then move on to debugging your original software.
Checking the signals when under SPI control is best with an oscilloscope. Start with a loop that repeats a fixed pattern. If you do not have a 'scope, some multi-meters include a frequency counter that might help indicate parts of what is actually happening (i.e. clock frequency vs data and latch frequencies). With a low enough clock frequency (for debugging) you might even get by with a resistor and a speaker or headphone to probe the signals :-).
P.S. Your data and clock lines _DO_ have proper pull-up resistors?
This site uses cookies to store information on your computer. By continuing to use our site, you consent to our cookies. If you are not happy with the use of these cookies, please review our Cookie Policy to learn how they can be disabled. By disabling cookies, some features of the site will not work.
Mbed Community
I have the following circuit wired up to pinball lamps:
Here is the code I am using:
//MOSI TEST PROGRAM #include "mbed.h" SPI device(p5, p6, p7); // mosi, miso, scK DigitalOut pulse(p8); DigitalIn sw1(p29); //define input pins DigitalIn sw2(p30); int main() { device.format(16,3); //16 bits, positive edge or something device.write(0x00); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0xFF); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0x00); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0xFF); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0x00); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0xFF); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0x00); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0xFF); wait(0.75); pulse=1; wait(0.25); pulse=0; device.write(0x00); wait(0.75); pulse=1; wait(0.25); pulse=0;I can't get the lamps to respond properly.
Any suggestions?
Cheers David
