Hi!!
I'm working with a lcd with the ssd2119 controller, Im reading bitmaps on a SD card with the readPixel() command, but it seems to be too slow!!(about 3 ms per pixel on 24 bits)
I know that those 3 ms are because of the SD card (I get 15 fps when i send raw colors to the LCD)
the question is:
Can I get the entire row of colors of the bitmap at once?
How do I do that?
-I'm working with parallel bus,24 bits of color and sending data using Portout() command
-I'm also reading data from the SD card with SPI running at 12Mhz, I noticed that if i change the speed to 500Khz the speed is almost the same!!
Hi!! I'm working with a lcd with the ssd2119 controller, Im reading bitmaps on a SD card with the readPixel() command, but it seems to be too slow!!(about 3 ms per pixel on 24 bits) I know that those 3 ms are because of the SD card (I get 15 fps when i send raw colors to the LCD) the question is: Can I get the entire row of colors of the bitmap at once? How do I do that?
-I'm working with parallel bus,24 bits of color and sending data using Portout() command -I'm also reading data from the SD card with SPI running at 12Mhz, I noticed that if i change the speed to 500Khz the speed is almost the same!! :(
