it's bad enough that I can't really use ttmath because exceptions are disabled (please enable it and let the users choose whether or not to actually use it)... but I don't even know what's wrong with the instantiations
if I tried to compile the code like
typedef ttmath::Big<1,1> MyBig; // put this on top
#include <ttmath/ttmath.h>
#include <iostream>
ttmath::Parser<MyBig> parser;
const char equation[] = "(34 + 24) * 123 - 34.32 ^ 6 * sin(2.56) - atan(10)";
ttmath::ErrorCode err = parser.Parse(equation);
if (err == ttmath::err_ok) {
std::cout << parser.stack[0].value << std::endl;
else {
std::cout << "Error: "
<< static_cast<int>(err)
<< std::endl;
while (1);
then the compiler will not respond until I receive a 504 error (gateway timed out)
if I try
#include <ttmath/ttmathbig.h>
then I get the same errors as the first screenshot
then I added
#define TTMATH_DONT_USE_WCHAR
#define TTMATH_NOASM
#define TTMATH_PLATFORM32
to the top of the file, still doesn't help
how do I solve these errors? if you want to see ttmath, go http://www.ttmath.org/ or http://publicrep.ttmath.org/viewvc.py/ttmath/trunk/ttmath/ for the files
oh and i forgot to mention that the code is from the parser sample code
if I try
then I added
