Important update: Arm Announces End of Life Timeline for Mbed. This site will be archived in July 2026. Read the full announcement.
ADXL345 & ITG3200 on I2C
            Topic last updated  27 Jan 2011, by    Benny Brauwers.
                    1 reply
  Benny Brauwers.
                    1 reply
 Benny Brauwers.
                    1 reply
  Benny Brauwers.
                    1 reply
I use this code (below) to test a 6 Degree of Freedom Combo from SparkFun.
The Accelerator values displayed on the HyperTerminal are not stable within acceptable ranges.
Readings can be from –app5000 to +app5000 without touching the sensor.
Since I have 2 of those 6DOF, and both do have the same behaviour; my code is somewhere wrong.
But I do not see it….
Can someone use the red pen and point the error ?
Thanks in advance
Benny.
<<code>>
/#include "mbed.h"
// Test PRGM voor de Combo van SparkFun
// ITG-3200  triple axis digital gyroscope.
// ADXL345   triple axis, digital interface, accelerometer.
// Used mBed Pin's :
//     P01=  Gnd                    P11= SPI mosi               P21= Pwm Out                P31= USB D+
//     P02=  4.5v - 14.0v           P12= SPI miso               P22= Pwm Out                P32= USB D-
//     P03= VB                      P13= SPI sck, Serial Tx     P23= Pwm Out                P33= Ethernet TD+
//     P04= nR                      P14= Serial Rx              P24= Pwm Out                P34= Ethernet TD-
//     P05= SPI mosi                P15= Analog In              P25= Pwm Out                P35= Ethernet RD+
//     P06= SPI miso                P16= Analog In              P26= Pwm Out                P36= Ethernet RD-
//     P07= SPI sck                 P17= Analog In              P27= I2C scl, Serial Rx     P37= IF+
//     P08=                         P18= Analog In, Anal Out    P28= I2C sda, Serial Tx     P38= IF-
//     P09= I2C sda, Serial Tx      P19= Analog In              P29= CAN td                 P39= VU 5v USB out
//     P10= I2C scl, Serial Rx      P20= Analog In              P30= CAN rd                 P40= Vout 3.3v Regulated
//  AnalogIn myPotm1(p20);
DigitalOut myled(LED1)  ;
DigitalOut myled2(LED2) ;
DigitalOut myled3(LED3) ;
DigitalOut myled4(LED4) ;
int i=0                 ;   // Teller
int j=0                 ;   // Teller
float Gyro_Temp         ;
int Gyro_DevID          ;
int Acce_DevID          ;
int FiFo = 20           ;   // Aantal metingen voor de FiFo Buffer
// i2c Initialisation  --------------------------
I2C i2c(p9, p10)        ;           // sda, scl
// USB Serial init
Serial pc(USBTX, USBRX) ;           // tx, rx
// Gyro Registers ITG3200 Gyro //
//  Angular rate sensors.   14.375 LSBs per deg/sec and full-scale range of 2000 deg/sec, 16-bit ADC
//  Fast Mode I2C (400kHz) serial interface
#define Gyro_ITG3200_I2C_Address    0x68        //7-bit address.   01101000
#define    Gyro_Addr_Read           0xD1        //8-bit address.   011010001
#define    Gyro_Addr_Write          0xD0        //8-bit address.   011010000
#define    Gyro_Who_am_I_Reg        0x00
#define    Gyro_SMPLRT_DIV_Reg      0x15
#define    Gyro_DLPF_FS_Reg         0x16
#define    Gyro_INT_CFG_Reg         0x17
#define    Gyro_INT_Status          0x1A
#define    Gyro_Temp_out_H_Reg      0x1B        // 280 LSB/degC,  Offset: -13200 LSB = 35 degC, Range -30 to +85 degC
#define    Gyro_Temp_out_L_Reg      0x1C        //Offset = -35 degrees, 13200 counts. 280 counts/degrees C.
#define    Gyro_Xout_H_Reg          0x1D        //  Typical sensitivity is 14.375 LSB/(degrees/sec). Angular rate sensors
#define    Gyro_Xout_L_Reg          0x1E
#define    Gyro_Yout_H_Reg          0x1F
#define    Gyro_Yout_L_Reg          0x20
#define    Gyro_Zout_H_Reg          0x21
#define    Gyro_Zout_L_Reg          0x22
#define    Gyro_PWR_MGM_Reg         0x3E
// Gyro - Low Pass Filter Bandwidths //
#define     Gyro_LPFBW_256HZ        0x00
#define     Gyro_LPFBW_188HZ        0x01
#define     Gyro_LPFBW_98HZ         0x02
#define     Gyro_LPFBW_42HZ         0x03
#define     Gyro_LPFBW_20HZ         0x04
#define     Gyro_LPFBW_10HZ         0x05
#define     Gyro_LPFBW_5HZ          0x06
#define     Gyro_SleepMode          0x40
#define     Gyro_XYZ_StandbyMode    0x38
#define     Gyro_NormalMode         0x00
// Acce  Registers ADXL345 Accelerator //
// 13-bit resolution at �16 g (maintaining 4 mg/LSB scale factor in all g ranges)
// High resolution (3.9 mg/LSB) enables measurement of inclination changes less than 1.0 deg
#define Acce_ADXL345_I2C_Address        0x53    //7-bit address.   1010011
#define    Acce_Addr_Write              0xA6    //8-bit address.   10100110
#define    Acce_Addr_Read               0xA7    //8-bit address.   10100111
#define    Acce_DevID_Reg               0x00
#define    Acce_Thresh_TAP_Reg          0x1D
#define    Acce_OffsetX_Reg             0x1E
#define    Acce_OffsetY_Reg             0x1F
#define    Acce_OffsetZ_Reg             0x20
#define    Acce_DUR_Reg                 0x21
#define    Acce_Latent_Reg              0x22
#define    Acce_Window_Reg              0x23
#define    Acce_Thresh_ACT_Reg          0x24
#define    Acce_Thresh_INACT_Reg        0x25
#define    Acce_Time_INACT_Reg          0x26
#define    Acce_ACT_INACT_CTL_Reg       0x27
#define    Acce_Thresh_FF_Reg           0x28
#define    Acce_Time_FF_Reg             0x29
#define    Acce_TAP_Axes_Reg            0x2A
#define    Acce_ACT_TAP_Status_Reg      0x2B
#define    Acce_BW_Rate_Reg             0x2C
#define    Acce_Power_CTL_Reg           0x2D
#define    Acce_INT_Enable_Reg          0x2E
#define    Acce_INT_MAP_Reg             0x2F
#define    Acce_INT_Source_Reg          0x30
#define    Acce_Data_Format_Reg         0x31
#define    Acce_DataX0_Reg              0x32        // The output data is twos complement,
#define    Acce_DataX1_Reg              0x33        //  with DATAx0 as the least significant byte and
#define    Acce_DataY0_Reg              0x34        //  DATAx1 as the most significant byte
#define    Acce_DataY1_Reg              0x35
#define    Acce_DataZ0_Reg              0x36
#define    Acce_DataZ1_Reg              0x37
#define    Acce_FIFO_CTL_Reg            0x38
#define    Acce_FIFO_Status_Reg         0x39
//Data Rate Codes
#define    Acce_ADXL345_3200HZ          0x0F
#define    Acce_ADXL345_1600HZ          0x0E
#define    Acce_ADXL345_800HZ           0x0D
#define    Acce_ADXL345_400HZ           0x0C
#define    Acce_ADXL345_200HZ           0x0B
#define    Acce_ADXL345_100HZ           0x0A
#define    Acce_ADXL345_50HZ            0x09
#define    Acce_ADXL345_25HZ            0x08
#define    Acce_ADXL345_12HZ5           0x07
#define    Acce_ADXL345_6HZ25           0x06
#define    Acce_ADXL345_SPI_READ        0x80
#define    Acce_ADXL345_SPI_WRITE       0x00
#define    Acce_ADXL345_MULTI_BYTE      0x60
#define    Acce_ADXL345_X               0x00
#define    Acce_ADXL345_Y               0x01
#define    Acce_ADXL345_Z               0x02
#define    Acce_SleepMode               0x04
#define    Acce_NormalMode              0x08
   // HyperTerminal  Wissen van het scherm -----------------------------------------------------------
     pc.printf("\x1B\x48");        //Cursor Home
     pc.printf("\x1B\x4A");        //wissen vanaf Cursor
    int16_t aXout[FiFo+1]         ;       // FiFo om te averagen
    int16_t aYout[FiFo+1]         ;       // FiFo
    int16_t aZout[FiFo+1]         ;       // FiFo
    int16_t gXout[FiFo+1]         ;       // FiFo
    int16_t gYout[FiFo+1]         ;       // FiFo
    int16_t gZout[FiFo+1]         ;       // FiFo
    float aXoutAverage = 0        ;       // Averages
    float aYoutAverage = 0        ;       //
    float aZoutAverage = 0        ;       //
    float gXoutAverage = 0        ;       //
    float gYoutAverage = 0        ;       //
    float gZoutAverage = 0        ;       //
    for ( i=0 ; i <= FiFo ; i++ ) {
            aXout[i] = 0          ;       // initialiseren FiFO Buffers
            aYout[i] = 0          ;
            aZout[i] = 0          ;
            gXout[i] = 0          ;
            gXout[i] = 0          ;
            gXout[i] = 0          ;
    char tx[2]                    ;
    char rx[6]                    ;
      i2c.frequency(400000)       ;
    // Gyro Initialisation  --------------------------
     tx[0] = Gyro_DLPF_FS_Reg   ;   // 0x16 ,register die wij gaan vullen met tx[1]
     tx[1] = 0x03 << 3          ;   // FS_SEL bits sit in bits 4 and 3 (0x03) of DLPF_FS register. See datasheet for details. = 0x18
                                    // 2000deg/sec, 256Hz low passfilter bandwith, 8kHz sample rate
     i2c.write(Gyro_Addr_Write, tx, 2)  ;
     tx[0] = Gyro_PWR_MGM_Reg   ;        tx[1] = Gyro_NormalMode    ;
    // Acce Initialisation  --------------------------
     tx[0] = Acce_Power_CTL_Reg         ;       // Go into standby mode to configure the device.
     tx[1] = 0x00                       ;
     i2c.write(Acce_Addr_Write, tx, 2)  ;
     tx[0] = Acce_Data_Format_Reg       ;       // 0x0B : Full resolution, +/-16g, 4mg/LSB.
     tx[1] = 0x0B                       ;       // 0x08 : Full resolution, +/-2g,   mg/LSB.
     i2c.write(Acce_Addr_Write, tx, 2)  ;       // 0x00 : 10bit resolution,+/-2g,   mg/LSB.
     tx[0] = Acce_BW_Rate_Reg           ;       // 800Hz data rate.
     tx[1] = Acce_ADXL345_800HZ         ;
     tx[0] = Acce_Power_CTL_Reg         ;       // 0x08 : Measurement mode.
     tx[1] = 0x08                       ;
     wait(0.022)                        ;
        myled=1                         ;
   // Gyro ----------------------------------------------------------------------------------------------
        rx[0]=0, rx[1]=0, rx[2]=0, rx[3]=0, rx[4]=0, rx[5]=0 ;
        tx[0] = Gyro_Who_am_I_Reg                                           ;   // Gyro Id uitlezing
            i2c.write(Gyro_Addr_Write, tx, 1)                               ;
            i2c.read(Gyro_Addr_Read, rx, 1)                                 ;
            Gyro_DevID = (int) rx                                           ;
        tx[0] = Gyro_Temp_out_H_Reg                                         ;   // Gyro Temperatuur uitlezing
            i2c.read(Gyro_Addr_Read, rx, 2)                                 ;
            int16_t Gyro_OutputTemp = ((int) rx[0] << 8) | ((int) rx[1])    ;
            Gyro_Temp = ((13200+ (float)Gyro_OutputTemp )/280.0) +35.0;
        tx[0] = Gyro_Xout_H_Reg                                             ;   // Gyro X uitlezing
            int16_t Gyro_OutputX = ((int) rx[0] << 8) | ((int) rx[1])       ;
        tx[0] = Gyro_Yout_H_Reg                                             ;   // Gyro Y uitlezing
            int16_t Gyro_OutputY = ((int) rx[0] << 8) | ((int) rx[1])       ;
        tx[0] = Gyro_Zout_H_Reg                                             ;   // Gyro Z uitlezing
            int16_t Gyro_OutputZ = ((int) rx[0] << 8) | ((int) rx[1])       ;
    // Acce ---------------------------------------------------------------------------------------------------
        tx[0] = Acce_DevID_Reg                                              ;   // Acce Id uitlezing
            i2c.write(Acce_Addr_Write, tx, 1)                               ;
            i2c.read(Acce_Addr_Read, rx, 1)                                 ;
            Acce_DevID = (int) rx                                           ;
        tx[0] = Acce_DataX0_Reg                                             ;   // X,Y,Z na mekaar uitlezen
            i2c.read(Acce_Addr_Read, rx, 6)                                 ;
            int16_t Acce_OutputX = ((int) rx[0] << 8) | ((int) rx[1])       ;   // Acce X uitlezing
            int16_t Acce_OutputY = ((int) rx[2] << 8) | ((int) rx[3])       ;   // Acce Y uitlezing
            int16_t Acce_OutputZ = ((int) rx[4] << 8) | ((int) rx[5])       ;   // Acce Z uitlezing
        // FiFo vullen
        for ( i=FiFo-1 ; i >= 1 ; i-- ) {
             aXout[i] = aXout[i-1]          ;
             aYout[i] = aYout[i-1]          ;
             aZout[i] = aZout[i-1]          ;
             gXout[i] = gXout[i-1]          ;
             gYout[i] = gYout[i-1]          ;
             gZout[i] = gZout[i-1]          ;
        aXout[0] = Acce_OutputX             ;
 aYout[0] = Acce_OutputY             ;
        aZout[0] = Acce_OutputZ             ;
        gXout[0] = Gyro_OutputX             ;
        gYout[0] = Gyro_OutputY             ;
        gZout[0] = Gyro_OutputZ             ;
        for ( i=0 ; i <= FiFo-1 ; i++ ) {
            aXoutAverage = aXoutAverage +  (float)aXout[i] ;
            aYoutAverage = aYoutAverage +  (float)aYout[i] ;
            aZoutAverage = aZoutAverage +  (float)aZout[i] ;
            gXoutAverage = gXoutAverage +  (float)gXout[i] ;
            gYoutAverage = gYoutAverage +  (float)gYout[i] ;
            gZoutAverage = gZoutAverage +  (float)gZout[i] ;
        // Averaging
        aXoutAverage = aXoutAverage / ( float )FiFo    ;
        aYoutAverage = aYoutAverage / ( float )FiFo    ;
        aZoutAverage = aZoutAverage / ( float )FiFo    ;
        gXoutAverage = gXoutAverage / ( float )FiFo    ;
        gYoutAverage = gYoutAverage / ( float )FiFo    ;
        gZoutAverage = gZoutAverage / ( float )FiFo    ;
        j=j+1                   ;   // # metingen
    // HyperTerminal  ---------------------------------------------------------------------------------------------------
            //wait(0.1)   ;
            pc.printf("FiFo = %i    Meting = %i \n\n\r",FiFo, j )     ;
            pc.printf("gX %8.1f      gY %8.1f      gZ %8.1f         %4.1fC        \n\r",
                     gXoutAverage, gYoutAverage, gZoutAverage,  Gyro_Temp);
            pc.printf("aX %8.1f      aY %8.1f      aZ %8.1f          \n\n\r",
                     aXoutAverage, aYoutAverage, aZoutAverage);
            pc.printf("Id %i   gX %i    gY %i    gZ %i       gTemp %i   %4.1fC       \n\n\r",
                    Gyro_DevID, Gyro_OutputX, Gyro_OutputY, Gyro_OutputZ, Gyro_OutputTemp, Gyro_Temp);
            pc.printf("Id %i   aX %i    aY %i    aZ %i         \n\n\r",
                    Acce_DevID, Acce_OutputX, Acce_OutputY, Acce_OutputZ);
        aXoutAverage = 0        ;
        aYoutAverage = 0        ;
        aZoutAverage = 0        ;
        gXoutAverage = 0        ;
        gYoutAverage = 0        ;
        gZoutAverage = 0        ;
<</code>>
            I did find the error. It is much better like that :
int16_t Acce_OutputX = ((int) rx[1] << 8) | ((int) rx[0]) int16_t Acce_OutputY = ((int) rx[3] << 8) | ((int) rx[2]) int16_t Acce_OutputZ = ((int) rx[5] << 8) | ((int) rx[4])
Sorry...
Benny.
Sorry...
Benny.
I use this code (below) to test a 6 Degree of Freedom Combo from SparkFun. The Accelerator values displayed on the HyperTerminal are not stable within acceptable ranges. Readings can be from –app5000 to +app5000 without touching the sensor. Since I have 2 of those 6DOF, and both do have the same behaviour; my code is somewhere wrong. But I do not see it…. Can someone use the red pen and point the error ? Thanks in advance Benny.
/#include "mbed.h" // Test PRGM voor de Combo van SparkFun // ITG-3200 triple axis digital gyroscope. // ADXL345 triple axis, digital interface, accelerometer. // Used mBed Pin's : // P01= Gnd P11= SPI mosi P21= Pwm Out P31= USB D+ // P02= 4.5v - 14.0v P12= SPI miso P22= Pwm Out P32= USB D- // P03= VB P13= SPI sck, Serial Tx P23= Pwm Out P33= Ethernet TD+ // P04= nR P14= Serial Rx P24= Pwm Out P34= Ethernet TD- // P05= SPI mosi P15= Analog In P25= Pwm Out P35= Ethernet RD+ // P06= SPI miso P16= Analog In P26= Pwm Out P36= Ethernet RD- // P07= SPI sck P17= Analog In P27= I2C scl, Serial Rx P37= IF+ // P08= P18= Analog In, Anal Out P28= I2C sda, Serial Tx P38= IF- // P09= I2C sda, Serial Tx P19= Analog In P29= CAN td P39= VU 5v USB out // P10= I2C scl, Serial Rx P20= Analog In P30= CAN rd P40= Vout 3.3v Regulated // AnalogIn myPotm1(p20); DigitalOut myled(LED1) ; DigitalOut myled2(LED2) ; DigitalOut myled3(LED3) ; DigitalOut myled4(LED4) ; int i=0 ; // Teller int j=0 ; // Teller float Gyro_Temp ; int Gyro_DevID ; int Acce_DevID ; int FiFo = 20 ; // Aantal metingen voor de FiFo Buffer // i2c Initialisation -------------------------- I2C i2c(p9, p10) ; // sda, scl // USB Serial init Serial pc(USBTX, USBRX) ; // tx, rx //-----------------------------// // Gyro Registers ITG3200 Gyro // //-----------------------------// // Angular rate sensors. 14.375 LSBs per deg/sec and full-scale range of 2000 deg/sec, 16-bit ADC // Fast Mode I2C (400kHz) serial interface #define Gyro_ITG3200_I2C_Address 0x68 //7-bit address. 01101000 #define Gyro_Addr_Read 0xD1 //8-bit address. 011010001 #define Gyro_Addr_Write 0xD0 //8-bit address. 011010000 #define Gyro_Who_am_I_Reg 0x00 #define Gyro_SMPLRT_DIV_Reg 0x15 #define Gyro_DLPF_FS_Reg 0x16 #define Gyro_INT_CFG_Reg 0x17 #define Gyro_INT_Status 0x1A #define Gyro_Temp_out_H_Reg 0x1B // 280 LSB/degC, Offset: -13200 LSB = 35 degC, Range -30 to +85 degC #define Gyro_Temp_out_L_Reg 0x1C //Offset = -35 degrees, 13200 counts. 280 counts/degrees C. #define Gyro_Xout_H_Reg 0x1D // Typical sensitivity is 14.375 LSB/(degrees/sec). Angular rate sensors #define Gyro_Xout_L_Reg 0x1E #define Gyro_Yout_H_Reg 0x1F #define Gyro_Yout_L_Reg 0x20 #define Gyro_Zout_H_Reg 0x21 #define Gyro_Zout_L_Reg 0x22 #define Gyro_PWR_MGM_Reg 0x3E // Gyro - Low Pass Filter Bandwidths // #define Gyro_LPFBW_256HZ 0x00 #define Gyro_LPFBW_188HZ 0x01 #define Gyro_LPFBW_98HZ 0x02 #define Gyro_LPFBW_42HZ 0x03 #define Gyro_LPFBW_20HZ 0x04 #define Gyro_LPFBW_10HZ 0x05 #define Gyro_LPFBW_5HZ 0x06 #define Gyro_SleepMode 0x40 #define Gyro_XYZ_StandbyMode 0x38 #define Gyro_NormalMode 0x00 //-------------------------------------// // Acce Registers ADXL345 Accelerator // //-------------------------------------// // 13-bit resolution at �16 g (maintaining 4 mg/LSB scale factor in all g ranges) // High resolution (3.9 mg/LSB) enables measurement of inclination changes less than 1.0 deg #define Acce_ADXL345_I2C_Address 0x53 //7-bit address. 1010011 #define Acce_Addr_Write 0xA6 //8-bit address. 10100110 #define Acce_Addr_Read 0xA7 //8-bit address. 10100111 #define Acce_DevID_Reg 0x00 #define Acce_Thresh_TAP_Reg 0x1D #define Acce_OffsetX_Reg 0x1E #define Acce_OffsetY_Reg 0x1F #define Acce_OffsetZ_Reg 0x20 #define Acce_DUR_Reg 0x21 #define Acce_Latent_Reg 0x22 #define Acce_Window_Reg 0x23 #define Acce_Thresh_ACT_Reg 0x24 #define Acce_Thresh_INACT_Reg 0x25 #define Acce_Time_INACT_Reg 0x26 #define Acce_ACT_INACT_CTL_Reg 0x27 #define Acce_Thresh_FF_Reg 0x28 #define Acce_Time_FF_Reg 0x29 #define Acce_TAP_Axes_Reg 0x2A #define Acce_ACT_TAP_Status_Reg 0x2B #define Acce_BW_Rate_Reg 0x2C #define Acce_Power_CTL_Reg 0x2D #define Acce_INT_Enable_Reg 0x2E #define Acce_INT_MAP_Reg 0x2F #define Acce_INT_Source_Reg 0x30 #define Acce_Data_Format_Reg 0x31 #define Acce_DataX0_Reg 0x32 // The output data is twos complement, #define Acce_DataX1_Reg 0x33 // with DATAx0 as the least significant byte and #define Acce_DataY0_Reg 0x34 // DATAx1 as the most significant byte #define Acce_DataY1_Reg 0x35 #define Acce_DataZ0_Reg 0x36 #define Acce_DataZ1_Reg 0x37 #define Acce_FIFO_CTL_Reg 0x38 #define Acce_FIFO_Status_Reg 0x39 //Data Rate Codes #define Acce_ADXL345_3200HZ 0x0F #define Acce_ADXL345_1600HZ 0x0E #define Acce_ADXL345_800HZ 0x0D #define Acce_ADXL345_400HZ 0x0C #define Acce_ADXL345_200HZ 0x0B #define Acce_ADXL345_100HZ 0x0A #define Acce_ADXL345_50HZ 0x09 #define Acce_ADXL345_25HZ 0x08 #define Acce_ADXL345_12HZ5 0x07 #define Acce_ADXL345_6HZ25 0x06 #define Acce_ADXL345_SPI_READ 0x80 #define Acce_ADXL345_SPI_WRITE 0x00 #define Acce_ADXL345_MULTI_BYTE 0x60 #define Acce_ADXL345_X 0x00 #define Acce_ADXL345_Y 0x01 #define Acce_ADXL345_Z 0x02 #define Acce_SleepMode 0x04 #define Acce_NormalMode 0x08 // ITG-3200 triple axis digital gyroscope. // ADXL345 triple axis, digital interface, accelerometer. int main() { // HyperTerminal Wissen van het scherm ----------------------------------------------------------- pc.printf("\x1B\x48"); //Cursor Home pc.printf("\x1B\x4A"); //wissen vanaf Cursor int16_t aXout[FiFo+1] ; // FiFo om te averagen int16_t aYout[FiFo+1] ; // FiFo int16_t aZout[FiFo+1] ; // FiFo int16_t gXout[FiFo+1] ; // FiFo int16_t gYout[FiFo+1] ; // FiFo int16_t gZout[FiFo+1] ; // FiFo float aXoutAverage = 0 ; // Averages float aYoutAverage = 0 ; // float aZoutAverage = 0 ; // float gXoutAverage = 0 ; // float gYoutAverage = 0 ; // float gZoutAverage = 0 ; // for ( i=0 ; i <= FiFo ; i++ ) { aXout[i] = 0 ; // initialiseren FiFO Buffers aYout[i] = 0 ; aZout[i] = 0 ; gXout[i] = 0 ; gXout[i] = 0 ; gXout[i] = 0 ; } char tx[2] ; char rx[6] ; // i2c Initialisation -------------------------- i2c.frequency(400000) ; // Gyro Initialisation -------------------------- tx[0] = Gyro_DLPF_FS_Reg ; // 0x16 ,register die wij gaan vullen met tx[1] tx[1] = 0x03 << 3 ; // FS_SEL bits sit in bits 4 and 3 (0x03) of DLPF_FS register. See datasheet for details. = 0x18 // 2000deg/sec, 256Hz low passfilter bandwith, 8kHz sample rate i2c.write(Gyro_Addr_Write, tx, 2) ; tx[0] = Gyro_PWR_MGM_Reg ; tx[1] = Gyro_NormalMode ; i2c.write(Gyro_Addr_Write, tx, 2) ; // Acce Initialisation -------------------------- tx[0] = Acce_Power_CTL_Reg ; // Go into standby mode to configure the device. tx[1] = 0x00 ; i2c.write(Acce_Addr_Write, tx, 2) ; tx[0] = Acce_Data_Format_Reg ; // 0x0B : Full resolution, +/-16g, 4mg/LSB. tx[1] = 0x0B ; // 0x08 : Full resolution, +/-2g, mg/LSB. i2c.write(Acce_Addr_Write, tx, 2) ; // 0x00 : 10bit resolution,+/-2g, mg/LSB. tx[0] = Acce_BW_Rate_Reg ; // 800Hz data rate. tx[1] = Acce_ADXL345_800HZ ; i2c.write(Acce_Addr_Write, tx, 2) ; tx[0] = Acce_Power_CTL_Reg ; // 0x08 : Measurement mode. tx[1] = 0x08 ; i2c.write(Acce_Addr_Write, tx, 2) ; wait(0.022) ; while(1) { myled=1 ; // Gyro ---------------------------------------------------------------------------------------------- rx[0]=0, rx[1]=0, rx[2]=0, rx[3]=0, rx[4]=0, rx[5]=0 ; tx[0] = Gyro_Who_am_I_Reg ; // Gyro Id uitlezing i2c.write(Gyro_Addr_Write, tx, 1) ; i2c.read(Gyro_Addr_Read, rx, 1) ; Gyro_DevID = (int) rx ; tx[0] = Gyro_Temp_out_H_Reg ; // Gyro Temperatuur uitlezing i2c.write(Gyro_Addr_Write, tx, 1) ; i2c.read(Gyro_Addr_Read, rx, 2) ; int16_t Gyro_OutputTemp = ((int) rx[0] << 8) | ((int) rx[1]) ; Gyro_Temp = ((13200+ (float)Gyro_OutputTemp )/280.0) +35.0; tx[0] = Gyro_Xout_H_Reg ; // Gyro X uitlezing i2c.write(Gyro_Addr_Write, tx, 1) ; i2c.read(Gyro_Addr_Read, rx, 2) ; int16_t Gyro_OutputX = ((int) rx[0] << 8) | ((int) rx[1]) ; tx[0] = Gyro_Yout_H_Reg ; // Gyro Y uitlezing i2c.write(Gyro_Addr_Write, tx, 1) ; i2c.read(Gyro_Addr_Read, rx, 2) ; int16_t Gyro_OutputY = ((int) rx[0] << 8) | ((int) rx[1]) ; tx[0] = Gyro_Zout_H_Reg ; // Gyro Z uitlezing i2c.write(Gyro_Addr_Write, tx, 1) ; i2c.read(Gyro_Addr_Read, rx, 2) ; int16_t Gyro_OutputZ = ((int) rx[0] << 8) | ((int) rx[1]) ; // Acce --------------------------------------------------------------------------------------------------- rx[0]=0, rx[1]=0, rx[2]=0, rx[3]=0, rx[4]=0, rx[5]=0 ; tx[0] = Acce_DevID_Reg ; // Acce Id uitlezing i2c.write(Acce_Addr_Write, tx, 1) ; i2c.read(Acce_Addr_Read, rx, 1) ; Acce_DevID = (int) rx ; tx[0] = Acce_DataX0_Reg ; // X,Y,Z na mekaar uitlezen i2c.write(Acce_Addr_Write, tx, 1) ; i2c.read(Acce_Addr_Read, rx, 6) ; int16_t Acce_OutputX = ((int) rx[0] << 8) | ((int) rx[1]) ; // Acce X uitlezing int16_t Acce_OutputY = ((int) rx[2] << 8) | ((int) rx[3]) ; // Acce Y uitlezing int16_t Acce_OutputZ = ((int) rx[4] << 8) | ((int) rx[5]) ; // Acce Z uitlezing // FiFo vullen for ( i=FiFo-1 ; i >= 1 ; i-- ) { aXout[i] = aXout[i-1] ; aYout[i] = aYout[i-1] ; aZout[i] = aZout[i-1] ; gXout[i] = gXout[i-1] ; gYout[i] = gYout[i-1] ; gZout[i] = gZout[i-1] ; } aXout[0] = Acce_OutputX ; aYout[0] = Acce_OutputY ; aZout[0] = Acce_OutputZ ; gXout[0] = Gyro_OutputX ; gYout[0] = Gyro_OutputY ; gZout[0] = Gyro_OutputZ ; for ( i=0 ; i <= FiFo-1 ; i++ ) { aXoutAverage = aXoutAverage + (float)aXout[i] ; aYoutAverage = aYoutAverage + (float)aYout[i] ; aZoutAverage = aZoutAverage + (float)aZout[i] ; gXoutAverage = gXoutAverage + (float)gXout[i] ; gYoutAverage = gYoutAverage + (float)gYout[i] ; gZoutAverage = gZoutAverage + (float)gZout[i] ; } // Averaging aXoutAverage = aXoutAverage / ( float )FiFo ; aYoutAverage = aYoutAverage / ( float )FiFo ; aZoutAverage = aZoutAverage / ( float )FiFo ; gXoutAverage = gXoutAverage / ( float )FiFo ; gYoutAverage = gYoutAverage / ( float )FiFo ; gZoutAverage = gZoutAverage / ( float )FiFo ; j=j+1 ; // # metingen // HyperTerminal --------------------------------------------------------------------------------------------------- //wait(0.1) ; pc.printf("\x1B\x48"); //Cursor Home pc.printf("FiFo = %i Meting = %i \n\n\r",FiFo, j ) ; pc.printf("gX %8.1f gY %8.1f gZ %8.1f %4.1fC \n\r", gXoutAverage, gYoutAverage, gZoutAverage, Gyro_Temp); pc.printf("aX %8.1f aY %8.1f aZ %8.1f \n\n\r", aXoutAverage, aYoutAverage, aZoutAverage); pc.printf("Id %i gX %i gY %i gZ %i gTemp %i %4.1fC \n\n\r", Gyro_DevID, Gyro_OutputX, Gyro_OutputY, Gyro_OutputZ, Gyro_OutputTemp, Gyro_Temp); pc.printf("Id %i aX %i aY %i aZ %i \n\n\r", Acce_DevID, Acce_OutputX, Acce_OutputY, Acce_OutputZ); aXoutAverage = 0 ; aYoutAverage = 0 ; aZoutAverage = 0 ; gXoutAverage = 0 ; gYoutAverage = 0 ; gZoutAverage = 0 ; } }
