#include "math.h"
I2C i2c(p9, p10);
int I2C_ADDRESS = 0xEE; // sensor address
// oversampling setting
// 0 = ultra low power
// 1 = standard
// 2 = high
// 3 = ultra high resolution
const unsigned char oversampling_setting = 3; //oversampling for measurement
const unsigned char pressure_conversiontime[4] = {
4.5, 7.5, 13.5, 25.5 }; // delays for oversampling settings 0, 1, 2 and 3
// sensor registers from the BOSCH BMP085 datasheet
short ac1;
short ac2;
short ac3;
unsigned short ac4;
unsigned short ac5;
unsigned short ac6;
short b1;
short b2;
short mb;
short mc;
short md;
// variables to keep the values
float temperature = 0;
float pressure = 0;
void writeRegister(unsigned char r, unsigned char v)
char cmd1[2];
cmd1[0] = r;
cmd1[1] = v;
i2c.write(I2C_ADDRESS,cmd1, 2);
// read a 16 bit register
int readIntRegister(unsigned char r)
char cmd1[2];
char cmd2[1];
//unsigned char msb, lsb;
cmd2[0] = r;
i2c.write(I2C_ADDRESS,cmd2, 1);
i2c.read(I2C_ADDRESS, cmd1, 2);
return (((int)cmd1[0]<<8) | ((int)cmd1[1]));
// read uncompensated temperature value
unsigned int readUT() {
writeRegister(0xf4,0x2e);
wait(0.0045); // the datasheet suggests 4.5 ms
return readIntRegister(0xf6);
// read uncompensated pressure value
long readUP() {
writeRegister(0xf4,0x34+(oversampling_setting<<6));
wait(pressure_conversiontime[oversampling_setting]*0.001);
//unsigned char msb, lsb, xlsb;
char cmd1[3];
char cmd0[1];
cmd0[0] = 0xf6;
i2c.write(I2C_ADDRESS,cmd0, 1);
i2c.read(I2C_ADDRESS, cmd1, 3);
return (((long)cmd1[0]<<16) | ((long)cmd1[1]<<8) | ((long)cmd1[2])) >>(8-oversampling_setting);
// Below there are the utility functions to get data from the sensor.
// read temperature and pressure from sensor
void readSensor() {
long ut= readUT();
long up = readUP();
int x1, x2, x3, b3, b5, b6, p;
unsigned int b4, b7;
//calculate true temperature
x1 = ((long)ut - ac6) * ac5 >> 15;
x2 = ((long) mc << 11) / (x1 + md);
b5 = x1 + x2;
temperature = (b5 + 8) >> 4;
//calculate true pressure
b6 = b5 - 4000;
x1 = (b2 * (b6 * b6 >> 12)) >> 11;
x2 = ac2 * b6 >> 11;
x3 = x1 + x2;
if (oversampling_setting == 3) b3 = ((int32_t) ac1 * 4 + x3 + 2) << 1;
if (oversampling_setting == 2) b3 = ((int32_t) ac1 * 4 + x3 + 2);
if (oversampling_setting == 1) b3 = ((int32_t) ac1 * 4 + x3 + 2) >> 1;
if (oversampling_setting == 0) b3 = ((int32_t) ac1 * 4 + x3 + 2) >> 2;
x1 = ac3 * b6 >> 13;
x2 = (b1 * (b6 * b6 >> 12)) >> 16;
x3 = ((x1 + x2) + 2) >> 2;
b4 = (ac4 * (unsigned long) (x3 + 32768)) >> 15;
b7 = ((unsigned long) up - b3) * (50000 >> oversampling_setting);
p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
x1 = (p >> 8) * (p >> 8);
x1 = (x1 * 3038) >> 16;
x2 = (-7357 * p) >> 16;
pressure = p + ((x1 + x2 + 3791) >> 4);
void getCalibrationData() {
pc.printf("Reading Calibration Data");
ac1 = readIntRegister(0xAA);
pc.printf("AC1: %d\r\n",ac1);
ac2 = readIntRegister(0xAC);
pc.printf("AC2: %d\r\n",ac2);
ac3 = readIntRegister(0xAE);
pc.printf("AC3: %d\r\n",ac3);
ac4 = readIntRegister(0xB0);
pc.printf("AC4: %d\r\n",ac4);
ac5 = readIntRegister(0xB2);
pc.printf("AC5: %d\r\n",ac5);
ac6 = readIntRegister(0xB4);
pc.printf("AC6: %d\r\n",ac6);
b1 = readIntRegister(0xB6);
pc.printf("B1: %d\r\n",b1);
b2 = readIntRegister(0xB8);
pc.printf("B2: %d\r\n",b2);
mb = readIntRegister(0xBA);
pc.printf("MB: %d\r\n",mb);
mc = readIntRegister(0xBC);
pc.printf("MC: %d\r\n",mc);
md = readIntRegister(0xBE);
pc.printf("MD: %d\r\n",md);
float altitud(float p)
float To=298;
float ho=0;
float Po=101325;
//ecuacion
float c=(To-0.0065*ho);
float e=(p/Po);
float d=exp(0.19082*log(e));
float b=c*d;
float alt=153.84615*(To-b);
return(alt);
int main(){
pc.baud(9600);
getCalibrationData();
while(1)
readSensor();
pc.printf("Temperature: %.f Pressure: %.f Altitud: %.1f\r",temperature,pressure, altitud(pressure));
wait(1);
I had a question but i have already solve it. Here is the code. It works
