Excel
13 Feb 2011
Hello there. I am new to C and mbed. I am trying to save some data on office excel and create a chart with that data. I need to change rows and save each data array in different row. I have tried some examples from the web but they don't seem to work. Does anyone has an idea? Do I need some extra libraries to do this? Examples would be very helpful.
13 Feb 2011
If you are ALWAYS putting the data into a file, and then reading it back (from the MBED - from SD/USB drive of the local file system) later. then you will probably be best saving data off as a csv file, opening it with excel, and adding your chart etc, or you can paste the data into a pre-built excel form.
If you do want to directly create charts etc then you can use GOOGLE chart, although i have onley had limited susses with this.
Enjoy Ceri
13 Feb 2011
Really helpfull thanks. I am also looking on changing rows in excel. Do you know a way to do this(cause i have a quite big amount of data and when i save it it saves it in one row so copying and pasting may take some time)?
13 Feb 2011
IT Should be possible to write a Delphi program, To read I'm the data file. And send it to a specific row or col.
EG R8 n n n n n n
C4 n n n n
Enjoy Ceri.
23 Feb 2011
how much data youre talking about?
23 Feb 2011
Hello Marcel
I am talking about couple of hundreds of bytes, but i may reduce the amount.
24 Feb 2011
Georgios,
I'm doing a project where i take 5000 unsigned shorts samples (in one second). The .txt that it creates is about 40kb. and importing it into excel takes <1sec. When the program is complete i'll publish it.
24 Feb 2011
Ok Marcel thanks.
