I don't understand why you use an array, the present and previous value are sufficient for your calculation. You account for the sampling time in your calculation but you do not enforce this sampling time. The real results depends on your real signal, this is the difference between a mathematician and an engineer. A real world signal is not just 'sin x' but has a frequency, amplitude, phase, noise, offset etc.
Let's assume your signal is s(t)= A*sin(2*pi*f*t+phi) + B; your sampled signal is s(n)=A*sin(2*pi*f*n*T+phi) + B
Now you take the difference c(n+1) = (s(n+1)-s(n))/T = 2*A/T*sin(pi*f*T)*cos(2*pi*f*n*T+phi+pi*f*T)
for T very small this becomes A*2*pi*f*cos(2*pi*f*n*T+phi+pi*f*T);
so here you have your 'cos x' but as you can see is is scaled by 2*pi*f, which is to be expected even for mathematicians when you consider the chain rule.
you are absolutely correct..
i have made mistake there but now i am clear about that .
thank you so much.
And new question also arise here is that as we know the sin (2*theta)= 2*sin(theta) *cos(theta)
now if i do it in the external multiplication of the two signal then then it return signal is in double in frequency and complete sinusoidal in nature but same thing i do through the controller then return signal have positive hafl is there but negative half is not proper in shape even the frequency is not exactly double.
second problem is that if i try to take square of the signal then return signal is not correct, is it reason of data type of variable?
if i use the function pow(Ia,2) ,in this case also proper signal is return .
as mention above both cases the signals on which i perform the process,are individually verified many of times, they are correct in phase angle and magnitude vise.
so i don't get the point why it not multiplied two signals correctly.
one thing must br noted that in this process i remove the dc offset from the signal and for show on dac i add the dc offset in signal.
title
#include"mbed.h"
#include"math.h"
AnalogIn I(p17);
AnalogIn I1(p19);
AnalogOut aout(p18);
main()
int i;
double Ia,Ibeta,Ib,x;
static float dif_th,tan_x,tan_b;
while(1)
Ia=(I-0.5);
Ib=(I1-0.5);
Ibeta = (0.5774*Ia)+(2*0.5774*Ib);
x=Ia*Ia;
//x=pow(Ia,2);
aout=x+0.5;
hello friends
if any signal has to need differentiate it then how can we do it in mbed ?
as we know the differentiation of the sine signal is cos ,so if my input is sin then how can i get cos signal through the it
pls share the logic to differentiate the signals....
thank you.
