Umsae,
To display the value of 178, three calls to putc() would be necessary: putc('1'), putc('7'), and putc('8'). In hex these would be: putc(0x31), putc(0x37) and putc(0x38). The problem is you have to convert a value of 178, or B2h, into those three displayable characters. It's better to let printf() do that for you.
By the way, the ASCII codes for the numerals '0' to '9' are 30h to 39h. The uppercase alphabet starts 'A' at 41h, and the lowercase alphabet starts 'a' at 61h. And then there are punctuation and control codes. All of these occupy 00h to 7Fh, because the original ASCII had only seven bits. The paper tape used on teletype machines was about an inch wide and had tiny sprocket holes in the middle, with three slightly larger holes to the left of the sprocket holes and four holes to the right. It looked something like this:
<<tape>>
| o o o . o o o o |
| o o . o |
| o o . o o o |
| o o . o |
<</tape>>
When IBM came out with the PC, they realized that since a byte has eight bits, an 8-bit ASCII character set could have twice as many characters as a 7-bit ASCII character set. The characters from 80h to FFh were known as the extended character set. That is the range your value of B2h falls into.
Here is the part of the code im having problems with
int percent is passed in value 0-100
This is where im stuck I have tried everything I could google to try and figure this out myself but Im stumped. I get a value 0-100 do a calculation and get a value(I don't care about the loss of deciaml places in conversion to int). For a percent of 80 I need endcalc to be 178 and ?? to equal 0xB2. I have tried printf with %#X but I couldn't get it to work.
