servo left, middle and right
10 Feb 2012
hello,
i don´t find a code to control a servo over PWM into a DigitalIN.
my idea:
if DigitalIn left(p10)..............servo get to the left
if not DigitalIn left(p10)..........servo get to the middle
if DigitalIn right(p11..............servo get to the right
if not DigitalIn rigth(p11).........servo get to the middle
i have no ideas to do that? is this difficulty?
can anywhere help me??
thanks
10 Feb 2012
Checkout this page: http://mbed.org/cookbook/Servo
It should be easy to change this software into what you need by using 2 DigitalIn pins to control the servo instead of characters received on the serial port.
10 Feb 2012
i know.
my idea
  1. include "mbed.h"
  1. include "Servo.h"
DigitalIn taste(p10);
DigitalIn taste2(p12);
DigitalIn taste3(p11);
Servo myservo(p21);
float range = 0.0005;
float position = 0.5;
while(1)
switch() {
case 'taste': position = 0.0; break;
case 'taste2': position = 0.5; break;
case 'taste3': position = 1.0; break;
myservo.calibrate(range, 45.0);
myservo = position;
10 Feb 2012
it dosen´t work it
i am a absolute beginner
10 Feb 2012
For better visual code, using <<code>><</code>> tags is an option, just so you know it.
You want your servo to turn left, when told so, middle when told so, and right when told so?
include "mbed.h"
include "Servo.h"
Servo myservo(p21);
        switch () {
            case 'taste':
                position = 0.0;
                break;
            case 'taste2':
                position = 0.5;
                break;
            case 'taste3':
                position = 1.0;
                break;
                myservo = position;
That's your program. Try removing calibrate from the switch case, maybe that's doing something to it?
Lerche
10 Feb 2012
oh thanks for the tip.
jes this is the program that i written (copy/paste from servo page).
i don´t will use the usb serial with the key from keyboard (1,2,3...).
i will use the digital in options. I have 2 switches plugged to the mbed. the first for left forwarding, the second for right forwaring. is no switched to be used the servo go to the middle.
thanks for helping
11 Feb 2012
This should work. The switch statement above was wrong.
include "mbed.h"
include "Servo.h"
Servo myservo(p21);
   myservo.calibrate(range, 45.0); // init the servo
   while (1) {  // Do the next actions forever
        position = 0.5;      // default is middle position (no or both buttons pressed)
        // test to see if any buttons are pressed
        if (( taste) & (!taste2)) position = 0.0; // left on only taste pressed
        if ((!taste) & ( taste2)) position = 1.0; // right on only taste2 pressed
        myservo = position;             // activate the new position
The switch statement could be used like this.
include "mbed.h"
include "Servo.h"
Servo myservo(p21);
    int code;
        code = (taste3 * 4) + (taste2 * 2) + (taste); //binary encoded buttons
        switch (code) {
            case 1:
                position = 0.0; //taste
                break;
            case 2:
                position = 1.0; //taste2
                break;
            case 4:
                position = 0.5; //taste3
                break;
            default:
                position = 0.5; //all other combinations
                break;
        myservo = position;
11 Feb 2012
thanks! thats good.
but in the code is a little failure :-)
in the code line taste3 :-)
I use your code later at home.
Greets and thanks
