I would recomend that you either use an oscilloscope, to test the ACTUAL
Output from your sensor.
But if dont have one, or accses to one, then you need to try this;
Sample the voltage from your sensor, with at least 4 different currents.
Save as a text/csv file and load into excell.
I am guessing that the O / P will be positive, as well as negative.
Unless you have have cicuitry to shift the offset.
Alturnatly, you should be able to get a dedicated chip,
Hope this helps
Enjoy
Ceri
I'm trying to calculate RMS voltage from analog pin 19 so that I can convert that for working out the current reading from a CT sensor.
I've taken some working Arduino code and attempted to convert/replicate for MBED but my results are way off! Could one of you really experienced chaps take a look and see if you can steer me in the right direction?
My CT sensor outputs 1v AC that's linear to the current so I am offsetting with a volatage divider.
Thanks!
#include "mbed.h" // standard #include "TextLCD.h" // for the LCD AnalogIn CurAnalog(p19); // Read this for current TextLCD lcd(p21, p22, p23, p24, p25, p26); // re, e, d0, d1, d2, d3 DigitalOut Dummy1(p15); //doing this to help stabilise the analog readings DigitalOut Dummy2(p16); //doing this to help stabilise the analog readings DigitalOut Dummy3(p17); //doing this to help stabilise the analog readings DigitalOut Dummy4(p18); //doing this to help stabilise the analog readings //Setup variables int numberOfSamples = 3000; // CT: Voltage depends on current, burden resistor, and turns #define CT_BURDEN_RESISTOR 62 #define CT_TURNS 1800 //Calibration coeficients //These need to be set in order to obtain accurate results //Set the above values first and then calibrate futher using normal calibration method described on how to build it page. double ICAL = 1.046; double I_RATIO = (long double)CT_TURNS / CT_BURDEN_RESISTOR * 5 / 1024 * ICAL; //Sample variables int lastSampleI,sampleI; // was int, converted to float //Filter variables double lastFilteredI, filteredI; double filterTemp; //Power calculation variables double sqI,instP,sumI,sumP; //Useful value variables double realPower, apparentPower, powerFactor, Irms; // this is for getCurrent float getCurrent() { return CurAnalog.read(); }; // end of getCurrent int main() { int n; while(1) { //Reset accumulators - THIS SHOULD ALWAYS HAVE BEEN FIRST, NOT LAST sumI = 0; sampleI = 0; for (n=0; n<numberOfSamples; n++) { //Used for offset removal lastSampleI=sampleI; //Read in current samples. sampleI = (int)(getCurrent()*1024); //Used for offset removal lastFilteredI = filteredI; //Digital high pass filters to remove 1.65V DC offset. filteredI = 0.996*( lastFilteredI + (double)(sampleI-lastSampleI) ); //Root-mean-square method current //1) square current values sqI = (double)(filteredI * filteredI); //2) sum sumI += sqI; } Irms = (double)(I_RATIO*sqrt(sumI / (double)numberOfSamples)); lcd.printf(" %f\n", (float)Irms); // strictly speaking the cast to float isn't needed, but always good to be good wait(1); } }
