Importing usb audio project into online Compiler
31 Jul 2011
What is all this the Online Compiler is giving me
"the "packed" attribute is ignored in a typedef" in file "usb.h/"
Trying to publshed the usb reversing code with online compiler
the usb import has already being done for me but runing it to problems getting it work
as anybody got any of this stuff to work
http://mbed.org/users/frank26080115/programs/LPC1700CMSIS_Examples/lobvoi
http://mbed.org/users/frank26080115/programs/LPC1700CMSIS_Examples/lobvoi/docs/USBDEV_2USBAudio_2Abstract_8h_source.html
31 Jul 2011
"a value of type "void *" cannot be used to initialize an entity of type "fnGPDMACbs_Type *"" in file "lpc17xx_gpdma.c/<a href="#" onClick="window.open('/cookbook/Compiler-Error-144');">144</a>"
Somebody get the USBDEV of the Examples above working will they
31 Jul 2011
usb.h
 *      U S B  -  K e r n e l
 * Name:    usb.h
 * Purpose: USB Definitions
 * Version: V1.20
 *      This software is supplied "AS IS" without any warranties, express,
 *      implied or statutory, including but not limited to the implied
 *      warranties of fitness for purpose, satisfactory quality and
 *      noninfringement. Keil extends you a royalty-free right to reproduce
 *      and distribute executable files created using this software for use
 *      on NXP Semiconductors LPC family microcontroller devices only. Nothing
 *      else gives you the right to use this software.
 * Copyright (c) 2009 Keil - An ARM Company. All rights reserved.
#ifndef __USB_H__
#define __USB_H__
#include "lpc_types.h"
#if defined   (  __GNUC__  )
#define __packed __attribute__((__packed__))
#endif
#if defined     (  __CC_ARM  )
typedef __packed union {
#elif defined   (  __GNUC__  )
typedef union __packed {
#elif defined   (  __IAR_SYSTEMS_ICC__  )
#pragma pack(1)
typedef union {
#endif
  uint16_t W;
  __packed struct {
  struct __packed {
#pragma pack(1)
  struct {
#endif
    uint8_t L;
    uint8_t H;
  } WB;
#ifdef __IAR_SYSTEMS_ICC__
#pragma pack()
#endif
} WORD_BYTE;
#pragma pack()
#endif
/* bmRequestType.Dir */
#define REQUEST_HOST_TO_DEVICE     0
#define REQUEST_DEVICE_TO_HOST     1
/* bmRequestType.Type */
#define REQUEST_STANDARD           0
#define REQUEST_CLASS              1
#define REQUEST_VENDOR             2
#define REQUEST_RESERVED           3
/* bmRequestType.Recipient */
#define REQUEST_TO_DEVICE          0
#define REQUEST_TO_INTERFACE       1
#define REQUEST_TO_ENDPOINT        2
#define REQUEST_TO_OTHER           3
/* bmRequestType Definition */
typedef __packed union _REQUEST_TYPE {
typedef union __packed _REQUEST_TYPE {
#pragma pack(1)
typedef union _REQUEST_TYPE {
#endif
    __packed struct _BM {
    struct __packed _BM {
#pragma pack(1)
    struct _BM {
#endif
    uint8_t Recipient : 5;
    uint8_t Type      : 2;
    uint8_t Dir       : 1;
  } BM;
#pragma pack()
#endif
  uint8_t B;
} REQUEST_TYPE;
#pragma pack()
#endif
/* USB Standard Request Codes */
#define USB_REQUEST_GET_STATUS                 0
#define USB_REQUEST_CLEAR_FEATURE              1
#define USB_REQUEST_SET_FEATURE                3
#define USB_REQUEST_SET_ADDRESS                5
#define USB_REQUEST_GET_DESCRIPTOR             6
#define USB_REQUEST_SET_DESCRIPTOR             7
#define USB_REQUEST_GET_CONFIGURATION          8
#define USB_REQUEST_SET_CONFIGURATION          9
#define USB_REQUEST_GET_INTERFACE              10
#define USB_REQUEST_SET_INTERFACE              11
#define USB_REQUEST_SYNC_FRAME                 12
/* USB GET_STATUS Bit Values */
#define USB_GETSTATUS_SELF_POWERED             0x01
#define USB_GETSTATUS_REMOTE_WAKEUP            0x02
#define USB_GETSTATUS_ENDPOINT_STALL           0x01
/* USB Standard Feature selectors */
#define USB_FEATURE_ENDPOINT_STALL             0
#define USB_FEATURE_REMOTE_WAKEUP              1
/* USB Default Control Pipe Setup Packet */
typedef __packed struct _USB_SETUP_PACKET {
typedef struct __packed _USB_SETUP_PACKET {
#pragma pack(1)
typedef struct _USB_SETUP_PACKET {
#endif
  REQUEST_TYPE bmRequestType;
  uint8_t         bRequest;
  WORD_BYTE    wValue;
  WORD_BYTE    wIndex;
  uint16_t         wLength;
} USB_SETUP_PACKET;
#pragma pack()
#endif
/* USB Descriptor Types */
#define USB_DEVICE_DESCRIPTOR_TYPE                  1
#define USB_CONFIGURATION_DESCRIPTOR_TYPE           2
#define USB_STRING_DESCRIPTOR_TYPE                  3
#define USB_INTERFACE_DESCRIPTOR_TYPE               4
#define USB_ENDPOINT_DESCRIPTOR_TYPE                5
#define USB_DEVICE_QUALIFIER_DESCRIPTOR_TYPE        6
#define USB_OTHER_SPEED_CONFIG_DESCRIPTOR_TYPE      7
#define USB_INTERFACE_POWER_DESCRIPTOR_TYPE         8
#define USB_OTG_DESCRIPTOR_TYPE                     9
#define USB_DEBUG_DESCRIPTOR_TYPE                  10
#define USB_INTERFACE_ASSOCIATION_DESCRIPTOR_TYPE  11
/* USB Device Classes */
#define USB_DEVICE_CLASS_RESERVED              0x00
#define USB_DEVICE_CLASS_AUDIO                 0x01
#define USB_DEVICE_CLASS_COMMUNICATIONS        0x02
#define USB_DEVICE_CLASS_HUMAN_INTERFACE       0x03
#define USB_DEVICE_CLASS_MONITOR               0x04
#define USB_DEVICE_CLASS_PHYSICAL_INTERFACE    0x05
#define USB_DEVICE_CLASS_POWER                 0x06
#define USB_DEVICE_CLASS_PRINTER               0x07
#define USB_DEVICE_CLASS_STORAGE               0x08
#define USB_DEVICE_CLASS_HUB                   0x09
#define USB_DEVICE_CLASS_MISCELLANEOUS         0xEF
#define USB_DEVICE_CLASS_VENDOR_SPECIFIC       0xFF
/* bmAttributes in Configuration Descriptor */
#define USB_CONFIG_POWERED_MASK                0x40
#define USB_CONFIG_BUS_POWERED                 0x80
#define USB_CONFIG_SELF_POWERED                0xC0
#define USB_CONFIG_REMOTE_WAKEUP               0x20
/* bMaxPower in Configuration Descriptor */
#define USB_CONFIG_POWER_MA(mA)                ((mA)/2)
/* bEndpointAddress in Endpoint Descriptor */
#define USB_ENDPOINT_DIRECTION_MASK            0x80
#define USB_ENDPOINT_OUT(addr)                 ((addr) | 0x00)
#define USB_ENDPOINT_IN(addr)                  ((addr) | 0x80)
/* bmAttributes in Endpoint Descriptor */
#define USB_ENDPOINT_TYPE_MASK                 0x03
#define USB_ENDPOINT_TYPE_CONTROL              0x00
#define USB_ENDPOINT_TYPE_ISOCHRONOUS          0x01
#define USB_ENDPOINT_TYPE_BULK                 0x02
#define USB_ENDPOINT_TYPE_INTERRUPT            0x03
#define USB_ENDPOINT_SYNC_MASK                 0x0C
#define USB_ENDPOINT_SYNC_NO_SYNCHRONIZATION   0x00
#define USB_ENDPOINT_SYNC_ASYNCHRONOUS         0x04
#define USB_ENDPOINT_SYNC_ADAPTIVE             0x08
#define USB_ENDPOINT_SYNC_SYNCHRONOUS          0x0C
#define USB_ENDPOINT_USAGE_MASK                0x30
#define USB_ENDPOINT_USAGE_DATA                0x00
#define USB_ENDPOINT_USAGE_FEEDBACK            0x10
#define USB_ENDPOINT_USAGE_IMPLICIT_FEEDBACK   0x20
#define USB_ENDPOINT_USAGE_RESERVED            0x30
/* USB Standard Device Descriptor */
typedef __packed struct _USB_DEVICE_DESCRIPTOR {
typedef struct __packed _USB_DEVICE_DESCRIPTOR {
#pragma pack(1)
typedef struct _USB_DEVICE_DESCRIPTOR {
#endif
  uint8_t  bLength;
  uint8_t  bDescriptorType;
  uint16_t  bcdUSB;
  uint8_t  bDeviceClass;
  uint8_t  bDeviceSubClass;
  uint8_t  bDeviceProtocol;
  uint8_t  bMaxPacketSize0;
  uint16_t  idVendor;
  uint16_t  idProduct;
  uint16_t  bcdDevice;
  uint8_t  iManufacturer;
  uint8_t  iProduct;
  uint8_t  iSerialNumber;
  uint8_t  bNumConfigurations;
} USB_DEVICE_DESCRIPTOR;
#pragma pack()
#endif
/* USB 2.0 Device Qualifier Descriptor */
typedef __packed struct _USB_DEVICE_QUALIFIER_DESCRIPTOR {
typedef struct __packed _USB_DEVICE_QUALIFIER_DESCRIPTOR {
#pragma pack(1)
typedef struct _USB_DEVICE_QUALIFIER_DESCRIPTOR {
#endif
  uint8_t  bLength;
  uint16_t  bcdUSB;
  uint8_t  bReserved;
} USB_DEVICE_QUALIFIER_DESCRIPTOR;
#pragma pack()
#endif
/* USB Standard Configuration Descriptor */
typedef __packed struct _USB_CONFIGURATION_DESCRIPTOR {
typedef struct __packed _USB_CONFIGURATION_DESCRIPTOR {
#pragma pack(1)
typedef struct _USB_CONFIGURATION_DESCRIPTOR {
#endif
  uint8_t  bLength;
  uint16_t  wTotalLength;
  uint8_t  bNumInterfaces;
  uint8_t  bConfigurationValue;
  uint8_t  iConfiguration;
  uint8_t  bmAttributes;
  uint8_t  bMaxPower;
} USB_CONFIGURATION_DESCRIPTOR;
#pragma pack()
#endif
/* USB Standard Interface Descriptor */
typedef __packed struct _USB_INTERFACE_DESCRIPTOR {
typedef struct __packed _USB_INTERFACE_DESCRIPTOR {
#pragma pack(1)
typedef struct _USB_INTERFACE_DESCRIPTOR {
#endif
  uint8_t  bLength;
  uint8_t  bInterfaceNumber;
  uint8_t  bAlternateSetting;
  uint8_t  bNumEndpoints;
  uint8_t  bInterfaceClass;
  uint8_t  bInterfaceSubClass;
  uint8_t  bInterfaceProtocol;
  uint8_t  iInterface;
} USB_INTERFACE_DESCRIPTOR;
#pragma pack()
#endif
/* USB Standard Endpoint Descriptor */
typedef __packed struct _USB_ENDPOINT_DESCRIPTOR {
typedef struct __packed _USB_ENDPOINT_DESCRIPTOR {
#pragma pack(1)
typedef struct _USB_ENDPOINT_DESCRIPTOR {
#endif
  uint8_t  bLength;
  uint8_t  bEndpointAddress;
  uint16_t  wMaxPacketSize;
  uint8_t  bInterval;
} USB_ENDPOINT_DESCRIPTOR;
#pragma pack()
#endif
/* USB String Descriptor */
typedef __packed struct _USB_STRING_DESCRIPTOR {
typedef struct __packed _USB_STRING_DESCRIPTOR {
#pragma pack(1)
typedef struct _USB_STRING_DESCRIPTOR {
#endif
  uint8_t  bLength;
  uint16_t  bString/*[]*/;
} USB_STRING_DESCRIPTOR;
#pragma pack()
#endif
/* USB Common Descriptor */
typedef __packed struct _USB_COMMON_DESCRIPTOR {
typedef struct __packed _USB_COMMON_DESCRIPTOR {
#pragma pack(1)
typedef struct _USB_COMMON_DESCRIPTOR {
#endif
  uint8_t  bLength;
} USB_COMMON_DESCRIPTOR;
#pragma pack()
#endif
#endif  /* __USB_H__ */
lpc_types.h
 * @file        lpc_types.h
 * @brief        Contains the NXP ABL typedefs for C standard types.
 *                 It is intended to be used in ISO C conforming development
 *                 environments and checks for this insofar as it is possible
 *                 to do so.
 * @version        1.0
 * @date        27 Jul. 2008
 * @author        wellsk
 * Software that is described herein is for illustrative purposes only
 * which provides customers with programming information regarding the
 * products. This software is supplied "AS IS" without any warranties.
 * NXP Semiconductors assumes no responsibility or liability for the
 * use of the software, conveys no license or title under any patent,
 * copyright, or mask work right to the product. NXP Semiconductors
 * reserves the right to make changes in the software without
 * notification. NXP Semiconductors also make no representation or
 * warranty that such application will be suitable for the specified
 * use without further testing or modification.
/* Type group ----------------------------------------------------------- */
/** @defgroup LPC_Types LPC_Types
 * @ingroup LPC1700CMSIS_FwLib_Drivers
#ifndef LPC_TYPES_H
#define LPC_TYPES_H
/* Includes ------------------------------------------------------------------- */
#include <stdint.h>
/* Public Types --------------------------------------------------------------- */
/** @defgroup LPC_Types_Public_Types LPC_Types Public Types
 * @brief Boolean Type definition
typedef enum {FALSE = 0, TRUE = !FALSE} Bool;
 * @brief Flag Status and Interrupt Flag Status type definition
typedef enum {RESET = 0, SET = !RESET} FlagStatus, IntStatus, SetState;
#define PARAM_SETSTATE(State) ((State==RESET) || (State==SET))
 * @brief Functional State Definition
typedef enum {DISABLE = 0, ENABLE = !DISABLE} FunctionalState;
#define PARAM_FUNCTIONALSTATE(State) ((State==DISABLE) || (State==ENABLE))
 * @ Status type definition
typedef enum {ERROR = 0, SUCCESS = !ERROR} Status;
 * Read/Write transfer type mode (Block or non-block)
typedef enum
    NONE_BLOCKING = 0,        /**< None Blocking type */
    BLOCKING,                /**< Blocking type */
} TRANSFER_BLOCK_Type;
/** Pointer to Function returning Void (any number of parameters) */
typedef void (*PFV)();
/** Pointer to Function returning int32_t (any number of parameters) */
typedef int32_t(*PFI)();
/* Public Macros -------------------------------------------------------------- */
/** @defgroup LPC_Types_Public_Macros  LPC_Types Public Macros
/* _BIT(n) sets the bit at position "n"
 * _BIT(n) is intended to be used in "OR" and "AND" expressions:
 * e.g., "(_BIT(3) | _BIT(7))".
#undef _BIT
/* Set bit macro */
#define _BIT(n)    (1<<n)
/* _SBF(f,v) sets the bit field starting at position "f" to value "v".
 * _SBF(f,v) is intended to be used in "OR" and "AND" expressions:
 * e.g., "((_SBF(5,7) | _SBF(12,0xF)) & 0xFFFF)"
#undef _SBF
/* Set bit field macro */
#define _SBF(f,v) (v<<f)
/* _BITMASK constructs a symbol with 'field_width' least significant
 * bits set.
 * e.g., _BITMASK(5) constructs '0x1F', _BITMASK(16) == 0xFFFF
 * The symbol is intended to be used to limit the bit field width
 * thusly:
 * <a_register> = (any_expression) & _BITMASK(x), where 0 < x <= 32.
 * If "any_expression" results in a value that is larger than can be
 * contained in 'x' bits, the bits above 'x - 1' are masked off.  When
 * used with the _SBF example above, the example would be written:
 * a_reg = ((_SBF(5,7) | _SBF(12,0xF)) & _BITMASK(16))
 * This ensures that the value written to a_reg is no wider than
 * 16 bits, and makes the code easier to read and understand.
#undef _BITMASK
/* Bitmask creation macro */
#define _BITMASK(field_width) ( _BIT(field_width) - 1)
/* NULL pointer */
#ifndef NULL
#define NULL ((void*) 0)
#endif
/* Number of elements in an array */
#define NELEMENTS(array)  (sizeof (array) / sizeof (array[0]))
/* Static data/function define */
#define STATIC static
/* External data/function define */
#define EXTERN extern
#define MAX(a, b) (((a) > (b)) ? (a) : (b))
#define MIN(a, b) (((a) < (b)) ? (a) : (b))
/* Old Type Definition compatibility ------------------------------------------ */
/** @addtogroup LPC_Types_Public_Types LPC_Types Public Types
/** SMA type for character type */
typedef char CHAR;
/** SMA type for 8 bit unsigned value */
typedef uint8_t UNS_8;
/** SMA type for 8 bit signed value */
typedef int8_t INT_8;
/** SMA type for 16 bit unsigned value */
typedef    uint16_t UNS_16;
/** SMA type for 16 bit signed value */
typedef    int16_t INT_16;
/** SMA type for 32 bit unsigned value */
typedef    uint32_t UNS_32;
/** SMA type for 32 bit signed value */
typedef    int32_t INT_32;
/** SMA type for 64 bit signed value */
typedef int64_t INT_64;
/** SMA type for 64 bit unsigned value */
typedef uint64_t UNS_64;
/** 32 bit boolean type */
typedef Bool BOOL_32;
/** 16 bit boolean type */
typedef Bool BOOL_16;
/** 8 bit boolean type */
typedef Bool BOOL_8;
#endif /* LPC_TYPES_H */
/* --------------------------------- End Of File ------------------------------ */
"the "packed" attribute is ignored in a typedef" in file "usb.h/" line 27 col 8
"attributes ignored here" in file "adcuser.c/"
"argument of type "void *" is incompatible with parameter of type "std::uint8_t *"" in file "usbcore.c/<a href="#" onClick="window.open('/cookbook/Compiler-Error-167');">167</a>"
31 Jul 2011
The syntax conflict aswell:)?????????????????/
" Ignoring entry command. Cannot find argument 'Reset_Handler'." in file "/"
" Ignoring first command. Cannot find argument 'Reset_Handler'." in file "/"
31 Jul 2011
What all this stuff I am getting now?
 * Name:    usbcore.c
 * Purpose: USB Core Module
 * Version: V1.20
 * History:
 *          V1.20 Added vendor specific requests
 *                Changed string descriptor handling
 *                Reworked Endpoint0
 *          V1.00 Initial Version
#include "type.h"
#include "usb.h"
#include "usbcfg.h"
#include "usbhw.h"
#include "usbcore.h"
#include "usbdesc.h"
#include "usbuser.h"
#if (USB_CLASS)
#if (USB_AUDIO)
#include "audio.h"
#include "adcuser.h"
#endif
#if (USB_HID)
#include "hid.h"
#include "hiduser.h"
#endif
#if (USB_MSC)
#include "msc.h"
#include "mscuser.h"
extern MSC_CSW CSW;
#endif
#if (USB_CDC)
#include "cdc.h"
#include "cdcuser.h"
#endif
#endif
#if (USB_VENDOR)
#include "vendor.h"
#endif
#pragma diag_suppress 111,177,1441
uint16_t  USB_DeviceStatus;
uint8_t  USB_DeviceAddress;
uint8_t  USB_Configuration;
uint32_t USB_EndPointMask;
uint32_t USB_EndPointHalt;
uint32_t USB_EndPointStall;                         /* EP must stay stalled */
uint8_t  USB_NumInterfaces;
uint8_t  USB_AltSetting[USB_IF_NUM];
uint8_t  EP0Buf[USB_MAX_PACKET0];
USB_EP_DATA EP0Data;
USB_SETUP_PACKET SetupPacket;
 *  Reset USB Core
 *    Parameters:      None
 *    Return Value:    None
void USB_ResetCore (void) {
  USB_DeviceStatus  = USB_POWER;
  USB_DeviceAddress = 0;
  USB_Configuration = 0;
  USB_EndPointMask  = 0x00010001;
  USB_EndPointHalt  = 0x00000000;
  USB_EndPointStall = 0x00000000;
 *  USB Request - Setup Stage
 *    Parameters:      None (global SetupPacket)
void USB_SetupStage (void) {
  USB_ReadEP(0x00, (uint8_t *)&SetupPacket);
 *  USB Request - Data In Stage
 *    Parameters:      None (global EP0Data)
void USB_DataInStage (void) {
  uint32_t cnt;
  if (EP0Data.Count > USB_MAX_PACKET0) {
    cnt = USB_MAX_PACKET0;
  } else {
    cnt = EP0Data.Count;
  cnt = USB_WriteEP(0x80, EP0Data.pData, cnt);
  EP0Data.pData += cnt;
  EP0Data.Count -= cnt;
 *  USB Request - Data Out Stage
void USB_DataOutStage (void) {
  uint32_t cnt;
  cnt = USB_ReadEP(0x00, EP0Data.pData);
 *  USB Request - Status In Stage
 *    Parameters:      None
void USB_StatusInStage (void) {
  USB_WriteEP(0x80, NULL, 0);
 *  USB Request - Status Out Stage
 *    Parameters:      None
void USB_StatusOutStage (void) {
  USB_ReadEP(0x00, EP0Buf);
 *  Get Status USB Request
 *    Return Value:    TRUE - Success, FALSE - Error
__inline uint32_t USB_ReqGetStatus (void) {
  uint32_t n, m;
  switch (SetupPacket.bmRequestType.BM.Recipient) {
    case REQUEST_TO_DEVICE:
      EP0Data.pData = (uint8_t *)&USB_DeviceStatus;
      break;
    case REQUEST_TO_INTERFACE:
      if ((USB_Configuration != 0) && (SetupPacket.wIndex.WB.L < USB_NumInterfaces)) {
        *((__packed uint16_t *)EP0Buf) = 0;
        EP0Data.pData = EP0Buf;
      } else {
        return (FALSE);
      break;
    case REQUEST_TO_ENDPOINT:
      n = SetupPacket.wIndex.WB.L & 0x8F;
      m = (n & 0x80) ? ((1 << 16) << (n & 0x0F)) : (1 << n);
      if (((USB_Configuration != 0) || ((n & 0x0F) == 0)) && (USB_EndPointMask & m)) {
        *((__packed uint16_t *)EP0Buf) = (USB_EndPointHalt & m) ? 1 : 0;
      } else {
        return (FALSE);
      break;
    default:
      return (FALSE);
  return (TRUE);
 *  Set/Clear Feature USB Request
 *    Parameters:      sc:    0 - Clear, 1 - Set
 *                            (global SetupPacket)
__inline uint32_t USB_ReqSetClrFeature (uint32_t sc) {
  uint32_t n, m;
      if (SetupPacket.wValue.W == USB_FEATURE_REMOTE_WAKEUP) {
        if (sc) {
          USB_WakeUpCfg(TRUE);
          USB_DeviceStatus |=  USB_GETSTATUS_REMOTE_WAKEUP;
        } else {
          USB_WakeUpCfg(FALSE);
          USB_DeviceStatus &= ~USB_GETSTATUS_REMOTE_WAKEUP;
      } else {
        return (FALSE);
      break;
      return (FALSE);
      if ((USB_Configuration != 0) && ((n & 0x0F) != 0) && (USB_EndPointMask & m)) {
        if (SetupPacket.wValue.W == USB_FEATURE_ENDPOINT_STALL) {
          if (sc) {
            USB_SetStallEP(n);
            USB_EndPointHalt |=  m;
          } else {
            if ((USB_EndPointStall & m) != 0) {
              return (TRUE);
            USB_ClrStallEP(n);
#if (USB_MSC)
            if ((n == MSC_EP_IN) && ((USB_EndPointHalt & m) != 0)) {
              /* Compliance Test: rewrite CSW after unstall */
              if (CSW.dSignature == MSC_CSW_Signature) {
                USB_WriteEP(MSC_EP_IN, (uint8_t *)&CSW, sizeof(CSW));
#endif
            USB_EndPointHalt &= ~m;
        } else {
          return (FALSE);
      } else {
        return (FALSE);
      break;
    default:
      return (FALSE);
  return (TRUE);
 *  Set Address USB Request
__inline uint32_t USB_ReqSetAddress (void) {
      USB_DeviceAddress = 0x80 | SetupPacket.wValue.WB.L;
      break;
    default:
      return (FALSE);
  return (TRUE);
 *  Get Descriptor USB Request
__inline uint32_t USB_ReqGetDescriptor (void) {
  uint8_t  *pD;
  uint32_t len, n;
      switch (SetupPacket.wValue.WB.H) {
        case USB_DEVICE_DESCRIPTOR_TYPE:
          EP0Data.pData = (uint8_t *)USB_DeviceDescriptor;
          len = USB_DEVICE_DESC_SIZE;
          break;
        case USB_CONFIGURATION_DESCRIPTOR_TYPE:
          pD = (uint8_t *)USB_ConfigDescriptor;
          for (n = 0; n != SetupPacket.wValue.WB.L; n++) {
            if (((USB_CONFIGURATION_DESCRIPTOR *)pD)->bLength != 0) {
              pD += ((USB_CONFIGURATION_DESCRIPTOR *)pD)->wTotalLength;
          if (((USB_CONFIGURATION_DESCRIPTOR *)pD)->bLength == 0) {
            return (FALSE);
          EP0Data.pData = pD;
          len = ((USB_CONFIGURATION_DESCRIPTOR *)pD)->wTotalLength;
          break;
        case USB_STRING_DESCRIPTOR_TYPE:
          pD = (uint8_t *)USB_StringDescriptor;
            if (((USB_STRING_DESCRIPTOR *)pD)->bLength != 0) {
              pD += ((USB_STRING_DESCRIPTOR *)pD)->bLength;
          if (((USB_STRING_DESCRIPTOR *)pD)->bLength == 0) {
            return (FALSE);
          EP0Data.pData = pD;
		  len = ((USB_STRING_DESCRIPTOR *)EP0Data.pData)->bLength;
          break;
        default:
          return (FALSE);
      break;
#if USB_HID
        case HID_HID_DESCRIPTOR_TYPE:
          if (SetupPacket.wIndex.WB.L != USB_HID_IF_NUM) {
            return (FALSE);    /* Only Single HID Interface is supported */
          EP0Data.pData = (uint8_t *)USB_ConfigDescriptor + HID_DESC_OFFSET;
          len = HID_DESC_SIZE;
          break;
        case HID_REPORT_DESCRIPTOR_TYPE:
          EP0Data.pData = (uint8_t *)HID_ReportDescriptor;
          len = HID_ReportDescSize;
          break;
        case HID_PHYSICAL_DESCRIPTOR_TYPE:
          return (FALSE);      /* HID Physical Descriptor is not supported */
#endif
        default:
          return (FALSE);
      break;
    default:
      return (FALSE);
  if (EP0Data.Count > len) {
    EP0Data.Count = len;
  return (TRUE);
 *  Get Configuration USB Request
__inline uint32_t USB_ReqGetConfiguration (void) {
      EP0Data.pData = &USB_Configuration;
      break;
    default:
      return (FALSE);
  return (TRUE);
 *  Set Configuration USB Request
__inline uint32_t USB_ReqSetConfiguration (void) {
  USB_COMMON_DESCRIPTOR *pD;
  uint32_t alt = 0;
  uint32_t n, m;
      if (SetupPacket.wValue.WB.L) {
        pD = (USB_COMMON_DESCRIPTOR *)USB_ConfigDescriptor;
        while (pD->bLength) {
          switch (pD->bDescriptorType) {
              if (((USB_CONFIGURATION_DESCRIPTOR *)pD)->bConfigurationValue == SetupPacket.wValue.WB.L) {
                USB_Configuration = SetupPacket.wValue.WB.L;
                USB_NumInterfaces = ((USB_CONFIGURATION_DESCRIPTOR *)pD)->bNumInterfaces;
                for (n = 0; n < USB_IF_NUM; n++) {
                  USB_AltSetting[n] = 0;
                for (n = 1; n < 16; n++) {
                  if (USB_EndPointMask & (1 << n)) {
                    USB_DisableEP(n);
                  if (USB_EndPointMask & ((1 << 16) << n)) {
                    USB_DisableEP(n | 0x80);
                USB_EndPointStall= 0x00000000;
                USB_Configure(TRUE);
                if (((USB_CONFIGURATION_DESCRIPTOR *)pD)->bmAttributes & USB_CONFIG_POWERED_MASK) {
                  USB_DeviceStatus |=  USB_GETSTATUS_SELF_POWERED;
                } else {
                  USB_DeviceStatus &= ~USB_GETSTATUS_SELF_POWERED;
              } else {
                (uint8_t *)pD += ((USB_CONFIGURATION_DESCRIPTOR *)pD)->wTotalLength;
                continue;
              break;
            case USB_INTERFACE_DESCRIPTOR_TYPE:
              alt = ((USB_INTERFACE_DESCRIPTOR *)pD)->bAlternateSetting;
              break;
            case USB_ENDPOINT_DESCRIPTOR_TYPE:
              if (alt == 0) {
                n = ((USB_ENDPOINT_DESCRIPTOR *)pD)->bEndpointAddress & 0x8F;
                USB_EndPointMask |= m;
                USB_ConfigEP((USB_ENDPOINT_DESCRIPTOR *)pD);
                USB_EnableEP(n);
                USB_ResetEP(n);
              break;
          (uint8_t *)pD += pD->bLength;
      else {
            USB_DisableEP(n);
        USB_Configure(FALSE);
      if (USB_Configuration != SetupPacket.wValue.WB.L) {
        return (FALSE);
      break;
    default:
      return (FALSE);
  return (TRUE);
 *  Get Interface USB Request
__inline uint32_t USB_ReqGetInterface (void) {
        EP0Data.pData = USB_AltSetting + SetupPacket.wIndex.WB.L;
      } else {
        return (FALSE);
      break;
    default:
      return (FALSE);
  return (TRUE);
 *  Set Interface USB Request
__inline uint32_t USB_ReqSetInterface (void) {
  uint32_t ifn = 0, alt = 0, old = 0, msk = 0;
  uint32_t n, m;
  uint32_t set;
      if (USB_Configuration == 0) return (FALSE);
      set = FALSE;
            if (((USB_CONFIGURATION_DESCRIPTOR *)pD)->bConfigurationValue != USB_Configuration) {
              continue;
            break;
            ifn = ((USB_INTERFACE_DESCRIPTOR *)pD)->bInterfaceNumber;
            msk = 0;
            if ((ifn == SetupPacket.wIndex.WB.L) && (alt == SetupPacket.wValue.WB.L)) {
              set = TRUE;
              old = USB_AltSetting[ifn];
              USB_AltSetting[ifn] = (uint8_t)alt;
            break;
            if (ifn == SetupPacket.wIndex.WB.L) {
              if (alt == SetupPacket.wValue.WB.L) {
                USB_EnableEP(n);
                USB_ResetEP(n);
                msk |= m;
              else if ((alt == old) && ((msk & m) == 0)) {
                USB_EndPointMask &= ~m;
                USB_DisableEP(n);
           break;
      break;
    default:
      return (FALSE);
  return (set);
 *  USB Endpoint 0 Event Callback
 *    Parameters:      event
 *    Return Value:    none
void USB_EndPoint0 (uint32_t event) {
  switch (event) {
    case USB_EVT_SETUP:
      USB_SetupStage();
      USB_DirCtrlEP(SetupPacket.bmRequestType.BM.Dir);
      EP0Data.Count = SetupPacket.wLength;     /* Number of bytes to transfer */
      switch (SetupPacket.bmRequestType.BM.Type) {
        case REQUEST_STANDARD:
          switch (SetupPacket.bRequest) {
            case USB_REQUEST_GET_STATUS:
              if (!USB_ReqGetStatus()) {
                goto stall_i;
              USB_DataInStage();
              break;
            case USB_REQUEST_CLEAR_FEATURE:
              if (!USB_ReqSetClrFeature(0)) {
                goto stall_i;
              USB_StatusInStage();
#if USB_FEATURE_EVENT
              USB_Feature_Event();
#endif
              break;
            case USB_REQUEST_SET_FEATURE:
              if (!USB_ReqSetClrFeature(1)) {
                goto stall_i;
#endif
              break;
            case USB_REQUEST_SET_ADDRESS:
              if (!USB_ReqSetAddress()) {
                goto stall_i;
              break;
            case USB_REQUEST_GET_DESCRIPTOR:
              if (!USB_ReqGetDescriptor()) {
                goto stall_i;
              USB_DataInStage();
              break;
            case USB_REQUEST_SET_DESCRIPTOR:
/*stall_o:*/  USB_SetStallEP(0x00);            /* not supported */
              EP0Data.Count = 0;
              break;
            case USB_REQUEST_GET_CONFIGURATION:
              if (!USB_ReqGetConfiguration()) {
                goto stall_i;
              USB_DataInStage();
              break;
            case USB_REQUEST_SET_CONFIGURATION:
              if (!USB_ReqSetConfiguration()) {
                goto stall_i;
#if USB_CONFIGURE_EVENT
              USB_Configure_Event();
#endif
              break;
            case USB_REQUEST_GET_INTERFACE:
              if (!USB_ReqGetInterface()) {
                goto stall_i;
              USB_DataInStage();
              break;
            case USB_REQUEST_SET_INTERFACE:
              if (!USB_ReqSetInterface()) {
                goto stall_i;
#if USB_INTERFACE_EVENT
              USB_Interface_Event();
#endif
              break;
            default:
              goto stall_i;
          break;  /* end case REQUEST_STANDARD */
#if USB_CLASS
        case REQUEST_CLASS:
              goto stall_i;                                              /* not supported */
#if USB_HID
              if (SetupPacket.wIndex.WB.L == USB_HID_IF_NUM) {           /* IF number correct? */
                  case HID_REQUEST_GET_REPORT:
                    if (HID_GetReport()) {
                      EP0Data.pData = EP0Buf;                            /* point to data to be sent */
                      USB_DataInStage();                                 /* send requested data */
                      goto setup_class_ok;
                    break;
                  case HID_REQUEST_SET_REPORT:
                    EP0Data.pData = EP0Buf;                              /* data to be received */
                  case HID_REQUEST_GET_IDLE:
                    if (HID_GetIdle()) {
                    break;
                  case HID_REQUEST_SET_IDLE:
                    if (HID_SetIdle()) {
                      USB_StatusInStage();                               /* send Acknowledge */
                    break;
                  case HID_REQUEST_GET_PROTOCOL:
                    if (HID_GetProtocol()) {
                    break;
                  case HID_REQUEST_SET_PROTOCOL:
                    if (HID_SetProtocol()) {
                    break;
#endif  /* USB_HID */
#if USB_MSC
              if (SetupPacket.wIndex.WB.L == USB_MSC_IF_NUM) {           /* IF number correct? */
                  case MSC_REQUEST_RESET:
                    if ((SetupPacket.wValue.W == 0) &&	                 /* RESET with invalid parameters -> STALL */
                        (SetupPacket.wLength  == 0)) {
                      if (MSC_Reset()) {
                    break;
                  case MSC_REQUEST_GET_MAX_LUN:
                    if ((SetupPacket.wValue.W == 0) &&	                 /* GET_MAX_LUN with invalid parameters -> STALL */
                        (SetupPacket.wLength  == 1)) {
                      if (MSC_GetMaxLUN()) {
                        USB_DataInStage();
                    break;
#endif  /* USB_MSC */
#if USB_AUDIO
              if ((SetupPacket.wIndex.WB.L == USB_ADC_CIF_NUM)  ||       /* IF number correct? */
                  (SetupPacket.wIndex.WB.L == USB_ADC_SIF1_NUM) ||
                  (SetupPacket.wIndex.WB.L == USB_ADC_SIF2_NUM)) {
                  case AUDIO_REQUEST_GET_CUR:
                  case AUDIO_REQUEST_GET_MIN:
                  case AUDIO_REQUEST_GET_MAX:
                  case AUDIO_REQUEST_GET_RES:
                    if (ADC_IF_GetRequest()) {
                    break;
                  case AUDIO_REQUEST_SET_CUR:
//                case AUDIO_REQUEST_SET_MIN:
//                case AUDIO_REQUEST_SET_MAX:
//                case AUDIO_REQUEST_SET_RES:
#endif  /* USB_AUDIO */
#if USB_CDC
              if ((SetupPacket.wIndex.WB.L == USB_CDC_CIF_NUM)  ||       /* IF number correct? */
                  (SetupPacket.wIndex.WB.L == USB_CDC_DIF_NUM)) {
                  case CDC_SEND_ENCAPSULATED_COMMAND:
                    EP0Data.pData = EP0Buf;                              /* data to be received, see USB_EVT_OUT */
                  case CDC_GET_ENCAPSULATED_RESPONSE:
                    if (CDC_GetEncapsulatedResponse()) {
                    break;
                  case CDC_SET_COMM_FEATURE:
                  case CDC_GET_COMM_FEATURE:
                    if (CDC_GetCommFeature(SetupPacket.wValue.W)) {
                    break;
                  case CDC_CLEAR_COMM_FEATURE:
                    if (CDC_ClearCommFeature(SetupPacket.wValue.W)) {
                    break;
                  case CDC_SET_LINE_CODING:
                  case CDC_GET_LINE_CODING:
                    if (CDC_GetLineCoding()) {
                    break;
                  case CDC_SET_CONTROL_LINE_STATE:
                    if (CDC_SetControlLineState(SetupPacket.wValue.W)) {
                    break;
                  case CDC_SEND_BREAK:
                    if (CDC_SendBreak(SetupPacket.wValue.W)) {
                    break;
#endif  /* USB_CDC */
              /* end case REQUEST_TO_INTERFACE */
#if USB_AUDIO
                  if (ADC_EP_GetRequest()) {
                  break;
              goto stall_i;
              /* end case REQUEST_TO_ENDPOINT */
            default:
              goto stall_i;
setup_class_ok:                                                          /* request finished successfully */
          break;  /* end case REQUEST_CLASS */
#endif  /* USB_CLASS */
#if USB_VENDOR
        case REQUEST_VENDOR:
              if (!USB_ReqVendorDev(TRUE)) {
              break;
              if (!USB_ReqVendorIF(TRUE)) {
              break;
              if (!USB_ReqVendorEP(TRUE)) {
              break;
            default:
              goto stall_i;
          if (SetupPacket.wLength) {
            if (SetupPacket.bmRequestType.BM.Dir == REQUEST_DEVICE_TO_HOST) {
              USB_DataInStage();
          } else {
          break;  /* end case REQUEST_VENDOR */
#endif  /* USB_VENDOR */
        default:
stall_i:  USB_SetStallEP(0x80);
          EP0Data.Count = 0;
          break;
      break;  /* end case USB_EVT_SETUP */
    case USB_EVT_OUT:
      if (SetupPacket.bmRequestType.BM.Dir == REQUEST_HOST_TO_DEVICE) {
        if (EP0Data.Count) {                                             /* still data to receive ? */
          USB_DataOutStage();                                            /* receive data */
          if (EP0Data.Count == 0) {                                      /* data complete ? */
#if (USB_CLASS)
              case REQUEST_CLASS:
#if USB_HID
                          if (HID_SetReport()) {
                            goto out_class_ok;
                          break;
#if USB_AUDIO
                          if (ADC_IF_SetRequest()) {
                            goto out_class_ok;
                          break;
#if USB_CDC
                          if (CDC_SendEncapsulatedCommand()) {
                            goto out_class_ok;
                          break;
                          if (CDC_SetCommFeature(SetupPacket.wValue.W)) {
                            goto out_class_ok;
                          break;
                          if (CDC_SetLineCoding()) {
                            goto out_class_ok;
                          break;
                    goto stall_i;
#if USB_AUDIO
                        if (ADC_EP_SetRequest()) {
                          goto out_class_ok;
                        break;
                    goto stall_i;
                  default:
                    goto stall_i;
out_class_ok:                                                            /* request finished successfully */
#if USB_VENDOR
                    if (!USB_ReqVendorDev(FALSE)) {
                    break;
                    if (!USB_ReqVendorIF(FALSE)) {
                    break;
                    if (!USB_ReqVendorEP(FALSE)) {
                    break;
                  default:
                    goto stall_i;
              default:
                goto stall_i;
      } else {
        USB_StatusOutStage();                                            /* receive Acknowledge */
      break;  /* end case USB_EVT_OUT */
    case USB_EVT_IN :
        USB_DataInStage();                                               /* send data */
      } else {
        if (USB_DeviceAddress & 0x80) {
          USB_DeviceAddress &= 0x7F;
          USB_SetAddress(USB_DeviceAddress);
      break;  /* end case USB_EVT_IN */
    case USB_EVT_OUT_STALL:
      USB_ClrStallEP(0x00);
      break;
    case USB_EVT_IN_STALL:
      USB_ClrStallEP(0x80);
      break;
 * Name:    usbuser.c
 * Purpose: USB Custom User Module
 * Version: V1.20
#include "type.h"
#include "usb.h"
#include "usbcfg.h"
#include "usbhw.h"
#include "usbaudio.h"
 *  USB Power Event Callback
 *   Called automatically on USB Power Event
 *    Parameter:       power: On(TRUE)/Off(FALSE)
#if USB_POWER_EVENT
void USB_Power_Event (uint32_t  power) {
#endif
 *  USB Reset Event Callback
 *   Called automatically on USB Reset Event
#if USB_RESET_EVENT
void USB_Reset_Event (void) {
  USB_ResetCore();
#endif
 *  USB Suspend Event Callback
 *   Called automatically on USB Suspend Event
#if USB_SUSPEND_EVENT
void USB_Suspend_Event (void) {
#endif
 *  USB Resume Event Callback
 *   Called automatically on USB Resume Event
#if USB_RESUME_EVENT
void USB_Resume_Event (void) {
#endif
 *  USB Remote Wakeup Event Callback
 *   Called automatically on USB Remote Wakeup Event
#if USB_WAKEUP_EVENT
void USB_WakeUp_Event (void) {
#endif
 *  USB Start of Frame Event Callback
 *   Called automatically on USB Start of Frame Event
#if USB_SOF_EVENT
void USB_SOF_Event (void) {
#if USB_DMA == 0
  if (USB_ReadEP(0x03, (BYTE *)&DataBuf[DataIn])) {
    /* Data Available */
    DataIn += P_S;                          /* Update Data In Index */
    DataIn &= B_S - 1;                      /* Adjust Data In Index */
    if (((DataIn - DataOut) & (B_S - 1)) == (B_S/2)) {
      DataRun = 1;                          /* Data Stream running */
  } else {
    /* No Data */
    DataRun  = 0;                           /* Data Stream not running */
    DataOut  = DataIn;                      /* Initialize Data Indexes */
#endif
#endif
 *  USB Error Event Callback
 *   Called automatically on USB Error Event
 *    Parameter:       error: Error Code
#if USB_ERROR_EVENT
void USB_Error_Event (uint32_t error) {
#endif
 *  USB Set Configuration Event Callback
 *   Called automatically on USB Set Configuration Request
void USB_Configure_Event (void) {
  if (USB_Configuration) {                  /* Check if USB is configured */
    /* add your code here */
#endif
 *  USB Set Interface Event Callback
 *   Called automatically on USB Set Interface Request
void USB_Interface_Event (void) {
#endif
 *  USB Set/Clear Feature Event Callback
 *   Called automatically on USB Set/Clear Feature Request
void USB_Feature_Event (void) {
#endif
#define P_EP(n) ((USB_EP_EVENT & (1 << (n))) ? USB_EndPoint##n : NULL)
/* USB Endpoint Events Callback Pointers */
void (* const USB_P_EP[16]) (uint32_t event) = {
  P_EP(0),
  P_EP(1),
  P_EP(2),
  P_EP(3),
  P_EP(4),
  P_EP(5),
  P_EP(6),
  P_EP(7),
  P_EP(8),
  P_EP(9),
  P_EP(10),
  P_EP(11),
  P_EP(12),
  P_EP(13),
  P_EP(14),
  P_EP(15),
 *  USB Endpoint 1 Event Callback
 *   Called automatically on USB Endpoint 1 Event
 *    Parameter:       event
void USB_EndPoint1 (uint32_t event) {
 *  USB Endpoint 2 Event Callback
 *   Called automatically on USB Endpoint 2 Event
 *    Parameter:       event
void USB_EndPoint2 (uint32_t event) {
 *  USB Endpoint 3 Event Callback
 *   Called automatically on USB Endpoint 3 Event
 *    Parameter:       event
void USB_EndPoint3 (uint32_t event) {
#if USB_DMA
  USB_DMA_DESCRIPTOR DD;
  if (event & USB_EVT_OUT_DMA_EOT) {
    /* End of Transfer */
    if (USB_DMA_BufAdr(0x03) != ((uint32_t)DataBuf + 2*DataIn)) {
      DataIn += P_C*P_S;                    /* Update Data In Index */
    } else {
      /* No Data */
  if (event & (USB_EVT_OUT_DMA_EOT) | (USB_EVT_OUT_DMA_NDR)) {
    /* End of Transfer or New Descriptor Request */
    DD.BufAdr  = (uint32_t)DataBuf + 2*DataIn; /* DMA Buffer Address */
    DD.BufLen  = P_C;                       /* DMA Packet Count */
    DD.MaxSize = 0;                         /* Must be 0 for Iso Transfer */
    DD.InfoAdr = (uint32_t)InfoBuf;            /* Packet Info Buffer Address */
    DD.Cfg.Val = 0;                         /* Initial DMA Configuration */
    DD.Cfg.Type.IsoEP = 1;                  /* Iso Endpoint */
    USB_DMA_Setup (0x03, &DD);              /* Setup DMA */
    USB_DMA_Enable(0x03);                   /* Enable DMA */
#else
  event = event;
#endif
 *  USB Endpoint 4 Event Callback
 *   Called automatically on USB Endpoint 4 Event
 *    Parameter:       event
void USB_EndPoint4 (uint32_t event) {
 *  USB Endpoint 5 Event Callback
 *   Called automatically on USB Endpoint 5 Event
 *    Parameter:       event
void USB_EndPoint5 (uint32_t event) {
 *  USB Endpoint 6 Event Callback
 *   Called automatically on USB Endpoint 6 Event
 *    Parameter:       event
void USB_EndPoint6 (uint32_t event) {
 *  USB Endpoint 7 Event Callback
 *   Called automatically on USB Endpoint 7 Event
 *    Parameter:       event
void USB_EndPoint7 (uint32_t event) {
 *  USB Endpoint 8 Event Callback
 *   Called automatically on USB Endpoint 8 Event
 *    Parameter:       event
void USB_EndPoint8 (uint32_t event) {
 *  USB Endpoint 9 Event Callback
 *   Called automatically on USB Endpoint 9 Event
 *    Parameter:       event
void USB_EndPoint9 (uint32_t event) {
 *  USB Endpoint 10 Event Callback
 *   Called automatically on USB Endpoint 10 Event
 *    Parameter:       event
void USB_EndPoint10 (uint32_t event) {
 *  USB Endpoint 11 Event Callback
 *   Called automatically on USB Endpoint 11 Event
 *    Parameter:       event
void USB_EndPoint11 (uint32_t event) {
 *  USB Endpoint 12 Event Callback
 *   Called automatically on USB Endpoint 12 Event
 *    Parameter:       event
void USB_EndPoint12 (uint32_t event) {
 *  USB Endpoint 13 Event Callback
 *   Called automatically on USB Endpoint 13 Event
 *    Parameter:       event
void USB_EndPoint13 (uint32_t event) {
 *  USB Endpoint 14 Event Callback
 *   Called automatically on USB Endpoint 14 Event
 *    Parameter:       event
void USB_EndPoint14 (uint32_t event) {
 *  USB Endpoint 15 Event Callback
 *   Called automatically on USB Endpoint 15 Event
 *    Parameter:       event
void USB_EndPoint15 (uint32_t event) {
"expression must be a modifiable lvalue" in file "usbcore.c/<a href="#" onClick="window.open('/cookbook/Compiler-Error-137');">137</a>"
"operand types are incompatible ("void (*)(std::uint32_t)" and "void *")" in file "usbuser.c/"
Like 23 errors
31 Jul 2011
"a value of type "void *" cannot be used to initialize an entity of type "void (*const)(std::uint32_t)"" in file "usbuser.c/<a href="#" onClick="window.open('/cookbook/Compiler-Error-144');">144</a>"
31 Jul 2011
  1. if defined ( CC_ARM ) typedef packed union {
 * Name:    usb.h
 * Version: V1.20
#ifndef __USB_H__
#define __USB_H__
#endif
#pragma pack(1)
typedef union {
#endif
  uint16_t W;
  __packed struct {
  struct __packed {
#pragma pack(1)
  struct {
#endif
    uint8_t L;
    uint8_t H;
  } WB;
#pragma pack()
#endif
} WORD_BYTE;
#pragma pack()
#endif
#pragma pack(1)
#endif
#pragma pack(1)
	struct _BM {
#endif
    uint8_t Type      : 2;
    uint8_t Dir       : 1;
  } BM;
#pragma pack()
#endif
  uint8_t B;
} REQUEST_TYPE;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t         bRequest;
  WORD_BYTE    wValue;
  WORD_BYTE    wIndex;
  uint16_t         wLength;
} USB_SETUP_PACKET;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t  bLength;
  uint16_t  bcdUSB;
  uint16_t  idVendor;
  uint16_t  idProduct;
  uint16_t  bcdDevice;
  uint8_t  iProduct;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t  bLength;
  uint16_t  bcdUSB;
  uint8_t  bReserved;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t  bLength;
  uint8_t  bMaxPower;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t  bLength;
  uint8_t  iInterface;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t  bLength;
  uint8_t  bInterval;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t  bLength;
#pragma pack()
#endif
#pragma pack(1)
#endif
  uint8_t  bLength;
#pragma pack()
#endif
"attributes ignored here" in file "usbcore.c/"
  • ((packed uint16_t *)EP0Buf) = (USB_EndPointHalt & m) ? 1 : 0; EP0Data.pData = EP0Buf; } else { return (FALSE);
  1. if defined ( CC_ARM ) typedef packed union _REQUEST_TYPE {
 *      Name:    ADCUSER.C
 *      Purpose: Audio Device Class Custom User Module
 *      Version: V1.10
#include "usb.h"
#include "audio.h"
#include "usbcfg.h"
      uint16_t VolCur = 0x0100;     /* Volume Current Value */
const uint16_t VolMin = 0x0000;     /* Volume Minimum Value */
const uint16_t VolMax = 0x0100;     /* Volume Maximum Value */
const uint16_t VolRes = 0x0004;     /* Volume Resolution */
 *  Audio Device Class Interface Get Request Callback
 *   Called automatically on ADC Interface Get Request
 *    Parameters:      None (global SetupPacket and EP0Buf)
uint32_t ADC_IF_GetRequest (void) {
  Interface = SetupPacket.wIndex.WB.L;
  EntityID  = SetupPacket.wIndex.WB.H;
  Request   = SetupPacket.bRequest;
  Value     = SetupPacket.wValue.W;
  if (SetupPacket.wIndex.W == 0x0200) {
    /* Feature Unit: Interface = 0, ID = 2 */
    if (SetupPacket.wValue.WB.L == 0) {
      /* Master Channel */
        case AUDIO_MUTE_CONTROL:
              EP0Buf[0] = Mute;
              return (TRUE);
          break;
        case AUDIO_VOLUME_CONTROL:
              *((__packed uint16_t *)EP0Buf) = VolCur;
              return (TRUE);
              *((__packed uint16_t *)EP0Buf) = VolMin;
              return (TRUE);
              *((__packed uint16_t *)EP0Buf) = VolMax;
              return (TRUE);
              *((__packed uint16_t *)EP0Buf) = VolRes;
              return (TRUE);
          break;
  return (FALSE);  /* Not Supported */
 *  Audio Device Class Interface Set Request Callback
 *   Called automatically on ADC Interface Set Request
uint32_t ADC_IF_SetRequest (void) {
              Mute = EP0Buf[0];
              return (TRUE);
          break;
              VolCur = *((__packed uint16_t *)EP0Buf);
              return (TRUE);
          break;
 *  Audio Device Class EndPoint Get Request Callback
 *   Called automatically on ADC EndPoint Get Request
uint32_t ADC_EP_GetRequest (void) {
  EndPoint = SetupPacket.wIndex.WB.L;
 *  Audio Device Class EndPoint Set Request Callback
 *   Called automatically on ADC EndPoint Set Request
uint32_t ADC_EP_SetRequest (void) {
  • ((packed uint16_t *)EP0Buf) = VolCur;
 * @file        lpc_types.h
 *                 to do so.
 * @version        1.0
 * @author        wellsk
#ifndef LPC_TYPES_H
#define LPC_TYPES_H
#include <stdint.h>
typedef enum
#undef _BIT
/* Set bit macro */
#undef _SBF
 * bits set.
 * thusly:
#undef _BITMASK
/* NULL pointer */
#ifndef NULL
#endif
typedef char CHAR;
