Hello Daniel,
Very happy to receive your reply again.
Ya, I also few very hard to make it. I did google search the key work "autoip" as you mention. I did found the autoip.c/h library. There are few function for this library but wonder what parameter should i put it and the coding looking very complicated and i'm lose! hmmm.... :(
Quote:
Note from autoip.c
- USAGE:
- define LWIP_AUTOIP 1 in your lwipopts.h
- If you don't use tcpip.c (so, don't call, you don't call tcpip_init):
- - First, call autoip_init().
- - call autoip_tmr() all AUTOIP_TMR_INTERVAL msces,
- that should be defined in autoip.h.
- I recommend a value of 100. The value must divide 1000 with a remainder almost 0.
- Possible values are 1000, 500, 333, 250, 200, 166, 142, 125, 111, 100 ....
- Without DHCP:
- - Call autoip_start() after netif_add().
- With DHCP:
- - define LWIP_DHCP_AUTOIP_COOP 1 in your lwipopts.h.
- - Configure your DHCP Client.
Is there anything i can try with this library?
Quote:
void autoip_init(void);
void autoip_set_struct(struct netif *netif, struct autoip *autoip);
err_t autoip_start(struct netif *netif);
err_t autoip_stop(struct netif *netif);
void autoip_arp_reply(struct netif *netif, struct etharp_hdr *hdr);
void autoip_tmr(void);
void autoip_network_changed(struct netif *netif);
And i try to review back the sample code that i tried. I found out this EthernetTesterGood ( http://mbed.org/users/JeffM/programs/EthernetTesterGood/lgncop ) sample code don't have using setup ( eth.setup(); ). I wonder is there the possibility to make it work. Hopefully this the last chances for me to try.
Ya, i did tried hardware reset. It work's. Ya, good idea, instead of using h/w reset use software reset.
I'm now trying the code. Hopefully later can work!
Best Regards,
Wen
The following coding is successful compiled. What i tried to do in the coding is to configure the LAN ip either DHCP or fix ip rely on setting(p30). I can't get the fix-ip, I wonder why i always get the DHCP ip. Is there any wrong with my coding?
Thank you
