I'm trying to do a robot project using the Roving Networks RV 171 on serial Port p13,p14, I2C on p27,p28, 3 analog inputs and a PWM output. Also, using the PC USB for debug output.
Everything was going fine until I added the Wi-Fly, it seems, I can't run that serial port along with the others, I get no data from that port (I have used a serial to UART converter to listen to the output from the port and see zero data) :(
Are these blocks mutually exclusive? Which ports can I use to get data from all the blocks I need?
Ian
