Bare metal LPC11U24
18 Dec 2012
Hello, I'm trying to connect up a bare metal version of the M0 mbed and load a simple program onto it via the USB bootloader. I'm having some problems...
I'm using the 64-pin version. I have connected the ISP (pin 5) and RESET (pin 4)lines via switches to ground (with pull-ups), and the USB_CON (pin 29) to a P-channel MOSFET as per Chris' design. I also have USB_VBUS (pin 19) pulled up to 3V3.
My PC recognises a USB device but it doesn't come up as a MSD device and I can't open the folder or find it in device manager.
Can someone walk me through exactly what needs to be pulled where and pressed when to invoke the USB bootloader and get it to appear as a drive on my PC?
18 Dec 2012
0. apply 3,3V to the LPC11U24 1. Connect USB cable to your host PC. 2. have ISP# Low. 3. Take RESET# low, release it. 4. GNU/Linux (or if you must! Windows) should straightaway detect the removable drive.
Essential Check: the 12MHz crystal must be fitted. check it has no shorts, especially to V+ or GND
18 Dec 2012
Thanks for the replies guys, one thing I'm using a 10MHz xtal (didn't have a 12MHz one). I thought taht this would just make the MCU run a bit slower but now beginning to think this may be the problem?
I don't have a schematic at the minute as I'm hacking this on a prototyping board but the design is as Chris' design here with the exception that the resistors and caps on the USB side of things are the right way round!
Martin
18 Dec 2012
Bugger - got one on order should be coming in tomorrow...
I'm guess this is because of the USB clock frequencies??? Please explain for the unenlightened!
18 Dec 2012
USB timings are fixed - and the code must derive them from a known source.
12MHz crystal is indispensible, really.
18 Dec 2012
it is possible to program without crystal, if you use serial.
I have posted some detailed instructions, but cannot manage to find them using ny phone
Ceri
19 Dec 2012
the new xtal done the trick - all up and running. Surprisingly easy to program it in this way, I'm impressed!
01 Oct 2018
Thanks for helping to fix the problem. My configuration is DS-5 Debugger, covering all stages of product development ARM Compiler 5.03u3 for embedded and bare-metal code Linaro GCC Toolchain 2013.03 for Linux applications and Linux kernel ARM Streamline™ Performance Analyzer for various operating systems, including Linux, Android and RTX Eclipse IDE, source code editor and project manager Fixed Virtual Platforms (FVP) for Cortex™-A8 and quad-core Cortex-A9 processors Example projects and documentation . https://www.quickpayportal.me/
