I'm currently looking at hardware for a personal project/prototype. I'm hoping to use the new mbed in a portable device, so naturally I need a power source. In the past I've used a lithium-polymer battery, charger and dc-dc booster board. This approach seems pretty neat, until you try using the ADCs and the data is all over the place. I'm fairly sure the culprit was ripple/noise from the dc-dc converter that was being used to convert the 2.6-4.2v from the battery into 5v for the CPU and sensors. After quite a lot of reading around, I can see no way out of using a switching dc-dc converter while maintaining reasonable efficiency (even LDO regulators are very wasteful. This leaves me short of a power supply, as super-capacitors are too small and NiMh are bulky and heavy. I really don't want to use alkaline batteries, they're expensive when you have to keep buying them! I can't be the only person to have run into this problem, what's the best solution?
