Hi all
I am trying to drive some tls3001 ics they are 3 chan 12 bit Rgb drivers using 1 wire Manchester encoding for clk and data
The data sheet is in Chinese so I have run it through google translate and coded as far as I can.
but I think I am missing something vital with 1 section of data stream which is used for baudrtate detection by the ic
I have contacted the manufacturer but have had no luck there I Did also contact someone who made a controller for this device but they Said they had to sign an NDA so couldn't help and couldn't give me the name of their contact
If anyone has played with this ic at all or has any suggestions this would be very welcome especially the flow chart as this is the only thing google can't translate
Many thanks
Chris
Hi all I am trying to drive some tls3001 ics they are 3 chan 12 bit Rgb drivers using 1 wire Manchester encoding for clk and data
The data sheet is in Chinese so I have run it through google translate and coded as far as I can. but I think I am missing something vital with 1 section of data stream which is used for baudrtate detection by the ic
Many thanks Chris
