My hardware needs to be able to be powered from both USB (during configuration with a PC) and from a power pack (out in a field). The power pack will use a 5V regulator to power the mbed.
I also have an external IC that needs a 5V power supply and I want it to work regardless of the power source. It draws 2mA maximum.
Is there any reason why I cannot combine the external 5V supply with the USB 5V supply at the VU pin using two schottky zener diodes? Of course I need to take into account the voltage drop across the diodes.
thanks, Andy
