Low Cost FCC/CE/RoHs Wi-Fi Module support the Mbed Applications from WT8266
We know mbod is powerful in the IoT Wi-Fi applications, more and more people want to FCC/CE/RoHs certificated module for their mbed
applications, Wireless-Tag (www.wireless-tag.com) released one module WT8266 for maker market
• FCC/CE/RoHs certificated
• 32M bit Flash open for customer applications
• Dedicated tech support resource on http://bbs.wireless-tag.com/ for WT8266 module
• Completed software and tools for programming and development
• Rich Cloud support experience to sharing
This module is open for SEEED Studio
http://www.seeedstudio.com/depot/WT8266S1-WiFi-Module-p-2521.html?ref=newInBazaar
Besides this module wireless-tag provide other RF modules , including 433MHz, BLE, LoRa….
For more details you can contact support@wireless-tag.com
WT8266 Features
Core/Memory/System
• Tensilica L106, ultra-low power 32-bitmicro MCU, with 16-bit RSIC. The CPU clock speed is 80MHz. It can also reach a maximum value of 160MHz and Real Time Operation System (RTOS) is enabled
• RAM 36KB(Available)
• Flash 16Mbit
System
• 802.11 b/g/n
• WIFI 2.4 GHz, support WPA/WPA2
• Support STA/AP/STA+AP operation modes
• Integrated TCP/IP Stack
• Integrated TR switch, Balun, LNA, Power amplifier and matching network
• Integrated PLL, Regulator and power source management components
• PCB antenna
Radio/Power Consumption
• +20 dBm output power in 802.11b mode
• Deep sleep power <10uA, Power down leakage current < 5uA
• Wake up and transmit packets in < 2ms
• Standby power consumption < 1.0mW (DTIM3)
Peripherals and Interfaces
• Support SDIO 2.0, (H) SPI, UART, I2C, I2S, IR Remote Control, PWM, GPIO
• Supports MIMO 1×1 and 2×1, STBC, A-MPDU and A-MSDU aggregation and 0.4μs guard interval
• Integrated 10 bit high precision ADC
Support AT remote upgrades and cloud OTA upgrade
FCC/CE/RoHs
Size 18.6mm*15.0mm
Operating Voltage: 3.3V
Operating Temperature:-20-70°C
This module is open for SEEED Studio http://www.seeedstudio.com/depot/WT8266S1-WiFi-Module-p-2521.html?ref=newInBazaar
Besides this module wireless-tag provide other RF modules , including 433MHz, BLE, LoRa…. For more details you can contact support@wireless-tag.com
WT8266 Features Core/Memory/System • Tensilica L106, ultra-low power 32-bitmicro MCU, with 16-bit RSIC. The CPU clock speed is 80MHz. It can also reach a maximum value of 160MHz and Real Time Operation System (RTOS) is enabled • RAM 36KB(Available) • Flash 16Mbit System • 802.11 b/g/n • WIFI 2.4 GHz, support WPA/WPA2 • Support STA/AP/STA+AP operation modes • Integrated TCP/IP Stack • Integrated TR switch, Balun, LNA, Power amplifier and matching network • Integrated PLL, Regulator and power source management components • PCB antenna Radio/Power Consumption • +20 dBm output power in 802.11b mode • Deep sleep power <10uA, Power down leakage current < 5uA • Wake up and transmit packets in < 2ms • Standby power consumption < 1.0mW (DTIM3) Peripherals and Interfaces • Support SDIO 2.0, (H) SPI, UART, I2C, I2S, IR Remote Control, PWM, GPIO • Supports MIMO 1×1 and 2×1, STBC, A-MPDU and A-MSDU aggregation and 0.4μs guard interval • Integrated 10 bit high precision ADC Support AT remote upgrades and cloud OTA upgrade FCC/CE/RoHs Size 18.6mm*15.0mm Operating Voltage: 3.3V Operating Temperature:-20-70°C
