Hi Sanwal,
Does your Xbee routine use interrupts ? If I recall correctly it uses an uart to communicate with the mbed.
You could try to init VGA first and then the Xbee routines, the VGA library also changes the system clock frequency from 96 to 100 MHz, it should not be a problem for the uart functions as it is only 4% difference.
Another cause could be that the Xbee routines interfere with the IO port settings.
The VGA library is highly critical concerning timing, it uses interrupts and DMA to a strict schedule to display each line right on time.
Without analysing the Xbee routines I can not say what is causing this.
even if i use a delay of one mili second bto initialize the xbee before init_vga. it does not work.
* 640x480 60Hz fullgraphic monochrome VGA Driver demo program
* Copyright (C) 2011 by Ivo van Poorten <ivop(at)euronet.nl>
* and Gert van der Knokke <gertk(at)xs4all.nl>
* This file is licensed under the terms of the GNU Lesser
* General Public License, version 3.
* Inspired by Simon's (not Ford) Cookbook entry and Cliff Biffle's
* assembly code.
#include "vga640x480g.h"
Serial xbee1(p9, p10);
DigitalOut rst1(p11);
// visual feedback
DigitalOut myled(LED1);
DigitalOut myled1(LED2);
void vga(void)
myled1=1;
init_vga();
wait(0.001);
int s,t;
// serial port on at 115200 baud
//linktopc.baud(115200);
setbuf(stdout, NULL); // no buffering for this filehandle
// clear the screen
vga_cls();
// draw some circles
for (t=10; t<200; t+=5)
vga_circle(20+t,399-t,t,WHITE);
wait(0.04);
myled1=0;
// draw some boxes
for (t=10; t<100; t+=5)
vga_box(400+t,100+t,400+t*2,100+t*2,WHITE);
// circumfence the screen
vga_box(0,0,639,479,WHITE);
// show the complete character set
for (s=0; s<4; s++) {
for (t=0; t<64; t++) {
vga_putchar(20+t*8,20+16*s,t+s*64,WHITE);
// put a string on screen
vga_putstring(400,370,"Hello World!",WHITE);
myled1=0;
// draw some lines
vga_line(400,390,500,390,WHITE);
vga_line(500,475,600,375,WHITE);
// draw a filled box
vga_filledbox(450,330,550,360,1);
// draw some more boxes
for (t=10; t<320; t+=5)
vga_box(100+t,440-t/16,110+t,440+t/16,WHITE);
myled1=1;
// visual feedback
//DigitalOut myled(LED1);
// define serial port for debug
Serial linktopc(USBTX,USBRX);
wait(0.001);
vga();
rst1 = 0; //Set reset pin to 0
myled = 0;
myled1= 1;
wait_ms(1);
rst1 = 1; //Set reset pin to 1
wait_ms(1);
unsigned char buff[2000];
// init the VGA subsystem (always do this first!)
// all done
while (1){
wait(1);
myled=!myled;
would it work for reading files frm local file system?
If it works for one file why would it not work for more ? The only restriction is the amount of storage space on the local filesystem (2 Megabyte).
During the tests I did with VGA and the local filesystem I noticed that the screen output stops or gets corrupted so I used a SD card for storage and that works perfect and I have a lot more space.
