Ok, I've never heard that term before, I am a little new to most of the electronics work.
If they all lead directly to the battery isn't it effectively just a parallel circuit, just squished close together? That is what I have going on right now, I have a power rail that everything attaches into, no one component is getting its power from the ground of another (that is my understanding of the term daisy chaining).
I would never have thought of my wires being a problem, that was a good thing to check, but after a quick look I realized all the wires I am using are actually a slightly heavier gauge then those that come on the servo's or those that came as the battery leads. Making me think they would probably not be a cause of any problems.
I just tried throwing a 10ohm resistor on there this morning, without having any 0.1uf capacitors on hand to put on the servos, and it would seem that is not effective to filter just VIN/GND, with the resistor on VIN, a 0.1uf and a 220uf capacitor between VIN and GND. Still getting some serious stuttering, and blinking of the power light on the mbed.
I'll be picking up the supplies today, both a secondary power supply and the needed capacitors. If those don't work I will just go forward with the secondary power, I am on a very tight schedule so losing a couple days to this already has me nervous.
I have using an mbed with a gyro and 6 servo's for a robotics project. I am using a 6v power source (4 AA batteries) for the servo's. When I take the mbed off the USB and put it onto the 6v power source the power light just blinks on and off and the servo's sort of stutter. The mbed should run on 4.5-14v on the VIN, so I am not really sure why it would be doing this. It seems like the mbed is sucking power, with the mbed out of the circuit it will read at 6.03v solid, with it in the loop it drops down to about 5.7-5.8...
Any ideas?
