LED recommendation
17 Mar 2012
I am wanting to use the digital outputs on the mbed to drive LED's, now I think the digout is 3.3v... I need 3x LEDs (red, blue, & green)and need them as bright as possible. (the old style LED's, not surface mount)
Any recommendations on bright LED's I can use with the mbed? Ive had a quick look around farnells website but its hard to get a good idea how bright they will be.
Thanks ppl!
Steve
18 Mar 2012
The brightness is in MCD
Milli Candella or lumins.
Try searching for hyper bright.
I would use Farnell's search, Pick size, color then sort by brightness.
18 Mar 2012
But you need to check the current required by the LED vs the amount of current you can source from an mbed pin. Another option is to use some kind of LED driver.
Matt
18 Mar 2012
The formulae is simple:
V drop for LED = 3.3 - LED Voltage.
R = V Drop LED / Desired current.
Typical 2 to 6 mA,
And 220 to 1 K ohm.
Hope this is helps
Ceri.
19 Mar 2012
For smd I know that led like
1142615 (Farnell)
can bright a lot. Maybe they sell them in other package.
Regards Giuseppe
22 Mar 2012
Brilliant thanks for the information.
23 Mar 2012
I was looking at something like this...
http://uk.farnell.com/kingbright/l-7104qbc-g/led-3mm-blue-ultra-bright/dp/2080003?in_merch=New%20Products
Would that work if I put the correct resistor inline with it?
Anyone have any recommendations?
24 Mar 2012
Vf for that led is 3v3 @ 20mA You can drive it only if you run it between 2mA and 15mA which cause less light but it works.
24 Mar 2012
You are very close to the max output current of MBED. (pin)
If you only drive one LED then that will probably be ok.
I can't remember if max output current is 20 mA per pin, upto 100 mA total.
I think there is some good info if you keep clicking on The MBED pictures on home page.
Ceri
