The data sheet is so confusing that I thought some empirical measurements might be helpful.
The first question is, "What is the internal bias voltage at the XTAL1 input?". This is the center point around which the clock signal will swing after it passes through the 100pF coupling capacitor.
A scope showed the signal at XTAL1 swinging from about -0.4V to +2.4V. So it appears that the internal bias level is at the midpoint, or +1.0V.
The second question is, "How large an input signal can be allowed, given a 1.0V midpoint?"
The input level spec for the clock, Vi(XTAL1) is -0.8V minimum, +1.95V maximum. (Table 7, page 46). So the allowable input swing is 1.8V below the bias point, or 0.95V above the bias point.
For a signal that swings equally on both sides of the midpoint, the limit is given by the smaller of the two values above. So the maximum allowable input signal swing is +/- 0.95V, or 1.9Vpp. This equates to 950mV rms for an AC-coupled square wave; not so far off from the "1000mv (RMS)" maximum given on page 67 of the data sheet.
It looks like the mbed is being over driven a bit, with a +2.4V peak input. Since that is less than the supply voltage (3.3V), hopefully no protective diodes are being energized. Still, the overdrive can't be a Good Thing...
BTW, I suppose this overdrive is also present at the magic "mbed" chip, as it is also said to be in the ARM family.
Hi I’m confused and hope someone can help me out. Reading the data sheet (section 14.2) it describes two ways to clock the LPC1768. 1) Slave mode and 2) Oscillation mode. Looking at the MBED schematics mbed-005.1, the oscillator is not shown, but because there is a cap in series with pin 22 it makes me believe that they are using Slave mode. Well If that is the case I don't see the second cap (Cg on Fig 33) to attenuate the clock. Actually I used the scope and I get 3V pk. Which according to the data sheet that is it too much. The max should be 1.95 Vpk (Table 7) or 1.0 Vrms (page 68) Anyone out there using the slave mode?. Do you use Cg?
Thanks in advance
Jaime
Data sheet used is: http://ics.nxp.com/products/lpc1000/datasheet/lpc1763.lpc1764.lpc1765.lpc1766.lpc1767.lpc1768.lpc1769.pdf
