A project of mine that compiled in December no longer compiles. I get "Unable to download. Fix the reported errors...", but no errors are reported. Typically I found this after some tweaks to the code, but I have reverted the project back to earlier revisions and see the same.
Importing 'Hello World' project does compile, so I'm at a loss as to what to do.
Toby
Toby
I see your account is set as a beta tester. It's possible that you were using a beta server at the time of the failing compilation, there are no betas running right now so you'll be using the same live servers as everyone else.
I don't know of any compilation issues from January, but I'll check for you. I'm sorry we didn't spot this forum post at the time. If you ever have compilation issues in the online compiler again please email support@mbed.org as this will guarantee we'll spot the issue and start working to fix it.
Steve
Hi Toby,
If you want to change your betamode setting visit https://mbed.org/betamode/
Steve
Thanks Steve, the support address is noted and most welcome!
FWIW I think I opted out of beta mode a while ago*, and if I go check https://mbed.org/betamode/ now it says not active.
the fixes I needed worked their way into release, and then something happened that made me check whether it was beta mode causing it. I
* the fixes I needed worked their way into release, and then something happened that made me check whether it was beta mode causing it. I
Important Information for this Arm website
This site uses cookies to store information on your computer.
By continuing to use our site, you consent to our cookies.
If you are not happy with the use of these cookies, please review our
Cookie Policy
to learn how they can be disabled.
By disabling cookies, some features of the site will not work.
Access Warning
You do not have the correct permissions to perform this operation.
Toby
