recently I searched for the Code where the arm-gcc error/warning messages are parsed by mbed-cli compile.
After some hours of trail and fail I found the python method where it was parsed and I think this is done really complicated.
I changed the code from:
gcc.py error/warning parsing now
DIAGNOSTIC_PATTERN = re.compile('((?P<file>[^:]+):(?P<line>\d+):)(\d+:)? (?P<severity>warning|[eE]rror|fatal error): (?P<message>.+)')
INDEX_PATTERN = re.compile('(?P<col>\s*)\^')
def parse_output(self, output):
# The warning/error notification is multiline
msg = None
for line in output.splitlines():
match = self.DIAGNOSTIC_PATTERN.search(line)
if match is not None:
if msg is not None:
self.cc_info(msg)
msg = None
msg = {
'severity': match.group('severity').lower(),
'file': match.group('file'),
'line': match.group('line'),
'col': 0,
'message': match.group('message'),
'text': '',
'target_name': self.target.name,
'toolchain_name': self.name
elif msg is not None:
# Determine the warning/error column by calculating the ^ position
match = self.INDEX_PATTERN.match(line)
msg['col'] = len(match.group('col'))
self.cc_info(msg)
msg = None
else:
msg['text'] += line+"\n"
if msg is not None:
self.cc_info(msg)
to:
DIAGNOSTIC_PATTERN = re.compile('((?P<file>[^:]+):(?P<line>\d+):)(?P<col>\d+):? (?P<severity>warning|[eE]rror|fatal error): (?P<message>.+)')
msg = None
if msg is not None:
self.cc_info(msg)
msg = None
msg = {
'col': match.group('col'),
'text': '',
if msg is not None:
self.cc_info(msg)
I think this is more straight forward and does a better job, because sometimes the column parsing with counting space just fails (i.e. for FATFileSystem.cpp it shows for the warning at line 661:0, but in fact it is 661:16) and to be honest its more a hacky solution.
In my code it will be parsed from the arm-gcc output line instead of counting spaces and the second regex is not necessary.
What do you guys thinking?
Should I do a Pull Request?
recently I searched for the Code where the arm-gcc error/warning messages are parsed by mbed-cli compile. After some hours of trail and fail I found the python method where it was parsed and I think this is done really complicated. I changed the code from:
[...] DIAGNOSTIC_PATTERN = re.compile('((?P<file>[^:]+):(?P<line>\d+):)(\d+:)? (?P<severity>warning|[eE]rror|fatal error): (?P<message>.+)') INDEX_PATTERN = re.compile('(?P<col>\s*)\^') [...] def parse_output(self, output): # The warning/error notification is multiline msg = None for line in output.splitlines(): match = self.DIAGNOSTIC_PATTERN.search(line) if match is not None: if msg is not None: self.cc_info(msg) msg = None msg = { 'severity': match.group('severity').lower(), 'file': match.group('file'), 'line': match.group('line'), 'col': 0, 'message': match.group('message'), 'text': '', 'target_name': self.target.name, 'toolchain_name': self.name } elif msg is not None: # Determine the warning/error column by calculating the ^ position match = self.INDEX_PATTERN.match(line) if match is not None: msg['col'] = len(match.group('col')) self.cc_info(msg) msg = None else: msg['text'] += line+"\n" if msg is not None: self.cc_info(msg)to:
[...] DIAGNOSTIC_PATTERN = re.compile('((?P<file>[^:]+):(?P<line>\d+):)(?P<col>\d+):? (?P<severity>warning|[eE]rror|fatal error): (?P<message>.+)') [...] def parse_output(self, output): # The warning/error notification is multiline msg = None for line in output.splitlines(): match = self.DIAGNOSTIC_PATTERN.search(line) if match is not None: if msg is not None: self.cc_info(msg) msg = None msg = { 'severity': match.group('severity').lower(), 'file': match.group('file'), 'line': match.group('line'), 'col': match.group('col'), 'message': match.group('message'), 'text': '', 'target_name': self.target.name, 'toolchain_name': self.name } if msg is not None: self.cc_info(msg)I think this is more straight forward and does a better job, because sometimes the column parsing with counting space just fails (i.e. for FATFileSystem.cpp it shows for the warning at line 661:0, but in fact it is 661:16) and to be honest its more a hacky solution. In my code it will be parsed from the arm-gcc output line instead of counting spaces and the second regex is not necessary.
What do you guys thinking? Should I do a Pull Request?
