EFM32 flash_api.c
18 Jan 2018
I recently used or try to use the FLASH IAP on a EFM32 Pearl Gecko (EFM32PG12_STK3402) and found a "bug" in the flash_api.c. The flash_init() function should be changed from:
flash_api.c init actual
int32_t flash_init(flash_t *obj)
    (void)obj;
    return 0;
to
flash_api.c init should be
    (void)obj;
    MSC_Init();
    return 0;
and flash_free() function from:
flash_api.c deinit actual
int32_t flash_free(flash_t *obj)
    (void)obj;
    return 0;
to
flash_api.c deinit should be
    (void)obj;
    return 0;
With this changes you can use in your program the FLASH IAP without using the direct EFM32 Flash HAL init & deinit functions and the program portability should increase.
18 Jan 2018
Hi DBS 06,
can you send a patch via github pull request with the proposal? https://github.com/ARMmbed/mbed-os/pulls
23 Jan 2018
Of course! I would be happy to give something back to the community! :-)
