CPU: armv8m
I got an error caused by invalid value of SECURE_ALIAS_OFFSET when running UVISOR_GET_NS_ALIAS() in uvisor_pool_init().
Because IDAU is disabled on my target, I set SECURE_ALIAS_OFFSET to zero in platform/my_target/configuration.h, but SECURE_ALIAS_OFFSET is still 0x10000000 as defined in linker_exports.h.
The platform specific configurations are not applied to linker_exports.h. To fix this problem, you can add header inclusion ,uvisor-config.h, to linker_export.h or add compile option to CFLAGS as following
diff --git a/uvisor/Makefile b/uvisor/Makefile
index 5bb73a0..925f9c9 100644
--- a/uvisor/Makefile
+++ b/uvisor/Makefile
@@ -181,7 +181,8 @@ CFLAGS_PRE:=\
-I$(CORE_DIR) \
$(foreach DIR, $(CORE_INC_DIRS), -I$(DIR)) \
-ffunction-sections \
- -fdata-sections
+ -fdata-sections \
+ -include $(CORE_DIR)/uvisor-config.h
diff --git a/api/inc/linker_exports.h b/api/inc/linker_exports.h
index 2597fdc..e21af53 100644
--- a/api/inc/linker_exports.h
+++ b/api/inc/linker_exports.h
@@ -20,11 +20,13 @@
/* FIXME Consider supporting other aliasing schemes. This is dependent on the
* IDAU implementation. Not all aliasing is guaranteed to work the same way. We
* currently only support a 1-bit MSB IDAU. */
+#ifndef SECURE_ALIAS_OFFSET
#if defined (ARCH_CORE_ARMv8M) || defined (TARGET_M33)
# define SECURE_ALIAS_OFFSET 0x10000000
#else
#endif
+#endif
CPU: armv8m
