The mbed online compiler / editor should use tabs instead of spaces. That way, there are fewer keystrokes to hit if you want to lower the indent. (Or, at least, make it an option.)
I'm guessing it's not possible in a browser based application, as most browsers always use the tab key to change which controls are focused (you can press tab to move between buttons). Unless this shortcut can be turned off in the compiler, pressing tab would just select random buttons instead of entering a tab character.
Perhaps a different button could be used for tab, as a workaround?
Firefox, and I think IE does it too (I've not actively tested it in IE)
Important Information for this Arm website
This site uses cookies to store information on your computer.
By continuing to use our site, you consent to our cookies.
If you are not happy with the use of these cookies, please review our
Cookie Policy
to learn how they can be disabled.
By disabling cookies, some features of the site will not work.
Access Warning
You do not have the correct permissions to perform this operation.
