Ethernet + SD + local
17 Aug 2011
I'm using the web server with HTML code on a SD-card. To store some setup data I also open the local filesystem. If I use the local filesystem - the system stop if the web side is called. It also stop if the file on the local filesystem is closed before.
I have also test the new mbed lib.
Peter
