Hello
I imported EtherNetIf from this page[http://mbed.org/users/donatien/programs/EthernetNetIf/5z422], then hacked Donatien's UDPexample code to what you see here.
Calls to bind and sendto both return UDPSOCKET_MEM errors
regards
Dave
#include "EthernetNetIf.h"
#include "UDPSocket.h"
DigitalOut myled(LED1);
Serial pc(USBTX, USBRX);
EthernetNetIf eth;
UDPSocket cfgSocket;
void ShowError (UDPSocketErr udpErr)
switch ( udpErr )
case UDPSOCKET_OK:
pc.printf ("UDPSocket OK.\n");
break;
case UDPSOCKET_SETUP:
pc.printf ("UDPSocket not properly configured.\n");
break;
case UDPSOCKET_IF:
pc.printf ("Interface has problems, does not exist or is not initialized.\n");
break;
case UDPSOCKET_MEM:
pc.printf ("Not enough mem.\n");
break;
case UDPSOCKET_INUSE:
pc.printf ("Interface / Port is in use.\n");
break;
default:
pc.printf ("UNKnown UDP error\n");
break;
void onUDPSocketEvent(UDPSocketEvent e)
if ( e == UDPSOCKET_READABLE )
char buf[64] = {0};
Host host;
while( int len = cfgSocket.recvfrom( buf, 63, &host ) )
if( len <= 0 )
break;
pc.printf("From %d.%d.%d.%d: %s\n", host.getIp()[0], host.getIp()[1], host.getIp()[2], host.getIp()[3], buf);
pc.baud(115200);
pc.printf ("HEllo World - 7 *\n");
EthernetErr ethErr = eth.setup();
if( ethErr == ETH_OK )
IpAddr ip = eth.getIp();
pc.printf("mbed IP Address is %d.%d.%d.%d\r\n", ip[0], ip[1], ip[2], ip[3]);
else pc.printf ("ETHERNETSETUP FAILED\n");
cfgSocket.setOnEvent(&onUDPSocketEvent);
UDPSocketErr udpErr = cfgSocket.bind( Host(IpAddr(),5555) );
if ( udpErr != UDPSOCKET_OK )
ShowError(udpErr);
int i = 0;
Host brdHost(IpAddr(255,255,255,255), 5555); //broadcast test msg
char cfgRqstMsg[]="SERVER CONFIG REQUEST";
Timer tmr;
tmr.start();
while(1)
Net::poll();
if( tmr.read() > 5)
tmr.reset();
int nSent = cfgSocket.sendto(cfgRqstMsg,strlen(cfgRqstMsg),&brdHost);
pc.printf("PLONKER %d :: %d\n",++i,nSent);
if ( nSent < 0 )
ShowError((UDPSocketErr)nSent);
Hello
regards
Dave
#include "mbed.h" #include "EthernetNetIf.h" #include "UDPSocket.h" DigitalOut myled(LED1); Serial pc(USBTX, USBRX); EthernetNetIf eth; UDPSocket cfgSocket; void ShowError (UDPSocketErr udpErr) { switch ( udpErr ) { case UDPSOCKET_OK: pc.printf ("UDPSocket OK.\n"); break; case UDPSOCKET_SETUP: pc.printf ("UDPSocket not properly configured.\n"); break; case UDPSOCKET_IF: pc.printf ("Interface has problems, does not exist or is not initialized.\n"); break; case UDPSOCKET_MEM: pc.printf ("Not enough mem.\n"); break; case UDPSOCKET_INUSE: pc.printf ("Interface / Port is in use.\n"); break; default: pc.printf ("UNKnown UDP error\n"); break; } } void onUDPSocketEvent(UDPSocketEvent e) { if ( e == UDPSOCKET_READABLE ) { char buf[64] = {0}; Host host; while( int len = cfgSocket.recvfrom( buf, 63, &host ) ) { if( len <= 0 ) break; pc.printf("From %d.%d.%d.%d: %s\n", host.getIp()[0], host.getIp()[1], host.getIp()[2], host.getIp()[3], buf); } } } int main() { pc.baud(115200); pc.printf ("HEllo World - 7 *\n"); EthernetErr ethErr = eth.setup(); if( ethErr == ETH_OK ) { IpAddr ip = eth.getIp(); pc.printf("mbed IP Address is %d.%d.%d.%d\r\n", ip[0], ip[1], ip[2], ip[3]); } else pc.printf ("ETHERNETSETUP FAILED\n"); cfgSocket.setOnEvent(&onUDPSocketEvent); UDPSocketErr udpErr = cfgSocket.bind( Host(IpAddr(),5555) ); if ( udpErr != UDPSOCKET_OK ) ShowError(udpErr); int i = 0; Host brdHost(IpAddr(255,255,255,255), 5555); //broadcast test msg char cfgRqstMsg[]="SERVER CONFIG REQUEST"; Timer tmr; tmr.start(); while(1) { Net::poll(); if( tmr.read() > 5) { tmr.reset(); int nSent = cfgSocket.sendto(cfgRqstMsg,strlen(cfgRqstMsg),&brdHost); pc.printf("PLONKER %d :: %d\n",++i,nSent); if ( nSent < 0 ) ShowError((UDPSocketErr)nSent); } } }
