Error in schematic?
07 Nov 2010 . Edited: 07 Nov 2010
On the mbed-005.1 schematic sheet 3, I noticed DIP26 is listed as having P2.0/PWM1.1/TXD1/TRACECLK. This seems wrong. The datasheet says TRACECLK is on P2.6, which is not exported on the mbed. P2.0 only has three functions according to NXP. Or did they made a mistake?
--Ivo
user Christian Lerche wrote:
Well, I looked through the datasheet, and it seems that traceclk is connected to mbed p26 :-)
Which datasheet are you referring to? The ones I have seen, including the user manual (UM10360), specify the LPC1768 pins as:
pin 75: P2[0]/PWM1[1]/TXD1
pin 67: P2[6]/PCAP1[0]/RI1/TRACECLK
The mbed-005.1 schematic connects DIP26, which you call p26, to pin 75, but specifies pin 75 as:
