In the example code I constructed for this post: http://mbed.org/forum/mbed/topic/1012/
The warning isn't actually displayed in the compiler correctly.
This is the code:
struct Bitfield
unsigned char bit1:1;
Bitfield Test()
Bitfield bits; // "<bits.0> may be used before being set"
bits.bit1 = 1;
return bits;
What is displayed in the compiler output window is:
it was only once I copied the output to paste it in for the example, that I could see the <bits.0> section. I guess that it's simply not escaping the < & > before putting it in the HTML
This is the code:
struct Bitfield { unsigned char bit1:1; }; Bitfield Test() { Bitfield bits; // "<bits.0> may be used before being set" bits.bit1 = 1; return bits; }What is displayed in the compiler output window is:
